Help! Brake light constant hot - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 24Likes
post #1 of 18 Old 12-03-2018, 04:32 PM Thread Starter
WingVetteStrom's Avatar
2018 DL650XT. Hooked up Adventure Tech aux lighting and an Admore Light Bar. The Admore worked perfectly, so then I installed the ADV Tech aux lights. After I did that, the bike's OEM brake light is constantly hot/on. Disconnected the Admore and still have the problem, the disconnected the aux lighting and still have the problem. Cycled the rear and front brakes several times aggressively and that didn't fix the problem. How could installing the Adventure Tech lighting, or anything else, cause this to happen?
Any suggestions welcome.
2018 V-Strom 650XT
2018 Goldwing Tour DCT
2015 Z51 Corvette Stingray
WingVetteStrom is offline
post #2 of 18 Old 12-03-2018, 05:01 PM
Rolex's Avatar
99 times out of 100 it is the rear brake light switch needs adjusting.
The pedal is pulling on the switch, unhook the spring at the switch as a quick test.
If it is the switch you need to lower the switch to get more slack in the spring.
Big B, Brockie and trueblue550 like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 18 Old 12-03-2018, 05:49 PM Thread Starter
That was it!!!!!!!! I put on lowered foot pegs and lowered the rear brake pedal all the way to match. It never occurred to me that lowering the brake pedal would activate the switch. Poor design I guess.
Anyway, thanks so much!! May you be bestowed wealth and happiness throughout your days!!
Big B and Nicad like this.
2018 V-Strom 650XT
post #4 of 18 Old 12-03-2018, 07:05 PM
Not really a bad design, to my knowledge it's pretty much the only design on motorcycles for rear brakes. Glad it's figured out, this forum is a great resource!
Nicad likes this.
post #5 of 18 Old 12-03-2018, 07:30 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Phttt!
Someone didn't read the instructions or watch the video, or read the instructions sent with the parts to cal if he had questions..
Big B, V2man, Jarvis and 3 others like this.
richlandrick is offline
post #6 of 18 Old 12-03-2018, 07:34 PM
Well, it is a Male dominated hobby. What are these instructions you speak of?
Jarvis, BC Rider and Currenv like this.
realshelby is offline
post #7 of 18 Old 12-03-2018, 10:04 PM Thread Starter
Originally Posted by richlandrick View Post
Phttt!
Who is this cal that you speak of. :-O
2018 V-Strom 650XT
post #8 of 18 Old 12-03-2018, 10:05 PM Thread Starter
Ya, just think that adjusting a rear brake pedal to its lowest position shouldn't activate the switch. However, I should have put 2+2 together.
Brockie likes this.
2018 V-Strom 650XT
post #9 of 18 Old 12-03-2018, 10:47 PM
Brockie's Avatar
Phttt!
Bullseye. But hey, blokes only read the instructions as a last resort.
Brockie is offline
post #10 of 18 Old 12-04-2018, 12:41 AM Thread Starter
Um... What instructions. The one's that say: "If you adjust the rear pedal all the way down, the brake switch will be activated even though it's not supposed to be." :-O
2018 V-Strom 650XT
Front brake lever / brake light DanR DL1000A - 2014-2016 8 01-05-2016 02:58 AM
12 O'clock Labs Programmable Brake Light Flasher Module SV Racing Parts SV Racing Parts 1 03-03-2015 12:16 PM
4 Piston Brake Calipers Installed on ABS Bike Ruggybuggy DL650 and DL650A - 2004 to 2011 47 12-27-2012 10:25 AM
