Need AT GPS Mount Pic - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 31 Old 11-26-2018, 09:31 AM Thread Starter
Stromtrooper.com Sponsor
richlandrick's Avatar
I ws very surprised to find that I don't actually have any pics of our GPS mount installed on a 2017/2018 DL650. I very much appreciate it if someone with our GP mount instaled would take a couple of photos and forward them to me.
Thanks,
Rick
gary_lucas likes this.
richlandrick is offline
post #2 of 31 Old 11-26-2018, 12:29 PM
Last week I noticed the same. Was considering one for my '17 but hesitated because of lack of picture. Glad you're pursuing one.
brock29609 is offline
post #3 of 31 Old 11-26-2018, 12:36 PM
Send me an evaluation unit and I'll send you pics?
G
gary_lucas is offline
post #4 of 31 Old 11-26-2018, 12:51 PM
nvr2old's Avatar
Rick- A question about photos of your product. On the 2017 650 light bar the photo is of a 18 1000. Is the design so similar that the look is the same. Doing some farkle work for a friend and need to know before ordering.
Thanks Don.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #5 of 31 Old 11-26-2018, 10:34 PM
BKP
BKP's Avatar
Here you go, Rick. Fits like a glove. Sorry I couldn't get a front view... maybe when I pull off the Madstad...
richlandrick likes this.
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #6 of 31 Old 11-27-2018, 10:00 AM
Do you get any excessive vibration with it high up there?
...oh, and was it designed so that the ball faces forward or the rider? I suppose it works either way.
post #7 of 31 Old 11-27-2018, 10:45 AM
Rick, two questions about your mount.
  • Do we know that these flip up tabs on the Givi Airflow shield will clear the mount? I have the lower shield in the lowest setting.
  • Does the mount limit which height you can mount the shield at?
Edit
I installed one and the flip tabs do just barely clear the mounting bracket with the Airflow shield in the lowest position
post #8 of 31 Old 11-27-2018, 10:50 AM
BKP
BKP's Avatar
The ball can face either way. However, have it it face away from the rider seems to (more easily) set the GPS in alignment with the mount, and place it in a perfect viewing position.
Oh, and I get zero vibration traveling to the Zumo.
BKP is offline
post #9 of 31 Old 11-27-2018, 11:19 AM
BKP
BKP's Avatar
Edit...
I think this ruler confirms that the Givi Airflow and this GPS mount are incompatible, unless maybe you ride with the shield super tall. The tabs won't clear the mount. That's a real bummer.
I can't comment on the Airflow shield, as I have a Madstad. In my case, Rick's GPS mount mounts right inbetween the two Madstad brackets (see below). This leaves plenty of room to manipulate the adjustment wheels on the Madstad. All I needed to do was pick up a few slightly longer Madstad bracket screws to make up for the GPS mount's thickness.
[B][I]Barry[/I]
Madstad windscreen
BKP is offline
post #10 of 31 Old 11-27-2018, 12:00 PM
The only way it could possibly work with the Airflow would be to mount the latches upside down, so that you flip them up instead of down to secure the shield. Even then, not sure it would clear the mount. Too close to call, but it has a chance of working.
Edit: I was wrong. It works.
OEM top box is rocking on mount rubber bumpers? itsak9 V-Strom Service and Maintenance Questions and Discussions 4 07-08-2011 10:28 PM
Cheap & EZ way to mount a Pelican 1550 as a topcase Bisbonian V-Strom Modifications and Performance 2 04-01-2009 10:28 AM
