Koso Apollo Heated Grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 11-22-2018, 08:56 AM Thread Starter
Jarvis's Avatar
So I have this set of Koso Apollo Heated grips in my bin of unused parts from previous bikes that I think I will put on my 650XT.
Installation looks to be straight forward except for the fact they are about 10mm longer than the stock grips. I have read that Koso does not recommend cutting the grips and I noticed that I do have some extra room that may allow me to run the full grip.
Has anyone installed these and if so did you install at full length or did you cut the grips?
2018 DL650XT - Nomad
2012 WR250R - Rowen
2003 KTM 450 EXC - Hulk
Jarvis is offline
post #2 of 4 Old 11-22-2018, 09:15 AM
Motor7's Avatar
The left and right clusters have a pin that align with a hole in the handlebars to keep them from rotating. If you grind off that pin you can slide the clutch and throttle perch's in to make room for the grips. I have Oxfords and just cut them instead of removing the index pins.
This guy cut his Koso's though:
https://www.webbikeworld.com/koso-ap...-grips-review/
"This turned out to be correct, as we were able to trim the Koso grips as needed (to the groove at the outer edge of the grips, before the main body) without exposing or damaging any of the wiring inside the grip housing.
[UPDATE: Note that Koso warns against cutting the grips, but see photos above.]
Once they were trimmed, we finished the installation by using the included grip glue and then we slid the grips into place."
'15 DL650XT
Motor7 is offline
post #3 of 4 Old 11-22-2018, 11:01 PM
I installed the Koso Apolloís without trimming. See this thread: https://www.stromtrooper.com/showthr...82793?page=322
Post #3194
I purchased a new throttle tube to accommodate for the longer grips and the Suzukiís lip. I also added washers as spacers on the bar ends so the rubber grommet/nut wouldnít be pulled out of the bar when tightening the bar ends. I had to play with the tightness of the throttle side bar end to get it to work without rubbing the grip but I found the sweet spot and after a couple hundred miles Iím very happy. Clutch side grip is slightly hangs over the end of the bar but itís not noticeable once the end is on.
2018 V-Strom 650 XT - Champion Yellow
Rustlr63 is offline
post #4 of 4 Old 11-23-2018, 11:28 AM Thread Starter
Jarvis's Avatar
Post #3194
Thanks! Good info.
I realized that the Throttle Tube would need some work and had thought about buying a new one from Suzuki since it looked like they were less than $20 from RMATV but instead opted for a G2 Throttle Tamer instead. Although I think I like your solution better.
2012 WR250R - Rowen
Jarvis is offline
Heated grips & heated vest too? cforider DL650A - 2012-2016 26 05-19-2017 01:46 PM
New DL650 Owner Heated Grips Question norcal101 General V-Strom Discussion 9 12-25-2013 07:05 PM
6$ HEATED GRIPS? Your nuts. T-ville Trooper General V-Strom Discussion 37 02-25-2012 12:16 AM
Symtec heated grips stopped working on the Golden Gate Bridge today arooni V-Strom Service and Maintenance Questions and Discussions 1 09-10-2011 06:40 AM
