Puig Rear Tire Hugger install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 3 Post By Rustlr63
post #1 of 7 Old 11-18-2018, 11:43 AM Thread Starter
After emailing Puig to confirm compatibility (every retailer said it wasnít compatible with Ď17 and Ď18 650ís), I ordered their rear tire hugger from Amazon. The part number is 4710J. I must have got a return because mine arrived in non standard packaging but fortunately had all hardware except for foam tape that is used to protect the swing arm.
Tools needed: Phillips head screwdriver, socket wrench (a second is helpful in the later stages), hex drivers of sizes 4 and 6, a 10 mm socket (again a second will be helpful later), socket extensions, Allen key or similar long item to remove plastic push rivets, razor knife or other implement for cutting stock plastic. Optional would be a 10 mm crescent or box wrench in place of socket, and in my case gorilla double sided tape in place of the missing foam tape.
Step 1: size 6 hex to remove rear mounting bolt from pax foot peg. Loosen the forward and let it hang to access chain guard mounts
Step 2: Phillips screw driver to remove chain guard (I used my power drill)
Step 3: remove ABS plastic protector by rear shock. I used 10 mm socket on LOOOONG extension to reach from underneath.
There are two plastic pop rivets holding the back of the guard on. They are the same type that hold the front fairing together, use your Allen key to push the fastener through and pull them out. Because of the shape of the plastic guard youíll have to wiggle it out past the tire.
Step 4: cut the bottom lip off the guard. I used a razor knife. My Dremel sat in the corner and gave me dirty looks as I neglected it.
Resist the urge to put this back in place before you install the hugger. I found I didnít have room for my socket wrench and had to remove it a second time.
Step 5: fit the supplied bracket over the right side swing arm. This is where I used my two 10 mm sockets. I also had to use the gorilla tape as my package Didnít have the foam tape.
Keep it loose until the hugger is in place so you can adjust the position as needed. Youíll need to shimmy it under the brake line.
Step 6: insert the four supplied well nuts into hugger. Slide the hugger in place and use the size 4 hex socket to tighten the screws. Full disclosure, itís tight around the exhaust. I used the Allen key that came with the bike. Once you have the exhaust side secured to the bracket you can tighten the screws around the swing arm.
Step 7: replace the ABS guard and the pax foot peg. I also added the double sided tape in a location that looked like it would rattle a little:
Itís between the swing arm and the hugger itself.
Done!
My only concern is that the stock chain guard included a metal bracket at the rear mounting position for stiffness that the hugger does not have. I make look to retrofit it to the hugger.
2018 V-Strom 650 XT - Champion Yellow
Rustlr63 is offline
post #2 of 7 Old 11-18-2018, 12:19 PM
BC Rider's Avatar
Thanks for the install pics. Been considering this for a while. How much room (aprox) between tire and hugger?
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #3 of 7 Old 11-18-2018, 04:30 PM
Rollin''s Avatar
Nice! Thanks for the install info.
Rollin' is offline
post #4 of 7 Old 11-18-2018, 08:17 PM Thread Starter
Give or take about an inch at the end of the tail but it is much less in the curved area. Probably a half inch.
Rustlr63 is offline
post #5 of 7 Old 11-18-2018, 09:02 PM
BC Rider's Avatar
On forestry roads I hear the odd rock run between the tire and the front fender. Would probably do the same in the rear.
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #6 of 7 Old 11-18-2018, 09:16 PM Thread Starter
You can raise the fender, AdventureTech sells a kit:http://www.adventuretech.biz/2012-dl...der-riser.html
Rustlr63 is offline
post #7 of 7 Old 11-18-2018, 11:40 PM
BC Rider's Avatar
Originally Posted by Rustlr63 View Post
You can raise the fender, AdventureTech sells a kit:2012+ DL650 Front Fender Riser - AdventureTech, LLC.
Interesting product. Was planning on a fork brace for Christmas. Might as well add in the fender raisers.
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
Flat tire - Dynaplug tire repair FAIL jokermtb V-Strom Service and Maintenance Questions and Discussions 18 09-11-2018 08:41 AM
Anyone willing to help change rear tire in Colorado, northeastern Utah, or southern Wyoming? Adventurefiend Midwest 1 08-02-2016 07:32 PM
My OEM rear tire - done at 14,000 KMS TooBigForWee DL650 and DL650A - 2004 to 2011 22 05-17-2014 06:35 PM
Rear tire slides first, why? Trepidator Riding Proficiency 39 04-29-2014 03:13 PM
Rear Flat Tire - Need advice PeterM DL650A - 2012-2016 10 04-21-2013 12:27 PM
