2017 650 Lowering Links ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 15 Old 11-16-2018, 05:57 PM Thread Starter
Rum Runner's Avatar
So my Wee Vee seems just a little tall for me. Just canít quite flat foot it. Looking at the lowering links from Pro Cycle. Used them on my KLR years ago and absolutely loved them. Like the way bike handled after that as well. Anyone used them? Pros and Cons? So far very little in mind for after market upgrades but a little bar rise and lowering links are the first 2 on the list.
Rum Runner is offline
post #2 of 15 Old 11-16-2018, 06:29 PM
I'm very glad to have the flexibility of soupy's adjustable height links. I've tweaked the height several time with just the turn of a wrench. I wouldn't want to be locked into a fixed height.
Also, try just lowering just the front fork first if all you need is a slight lowering. The bike will handle better with the forks sticking up 10-15 mm in the tree and the bike will feel slightly lower too.
chirosyd likes this.
brock29609 is offline
post #3 of 15 Old 11-16-2018, 08:45 PM
DonOhio45813's Avatar
Links are really quick n' easy to make, A 1" flat bar, 3/16 or 1/4" thick, drill 1/2" holes. Bolt 'em together at the one end before drilling the second set of holes, so they'll match perfect. Mine measure 6" center to center, for a 1" plus drop, on an 06 Wee. I found info that 5.9", is for a 1-1/8" drop, so mine must be 1-1/4". But I've ridden with a passenger, and never bottomed the rear tire against the inner fenderwell.
DonOhio45813 is offline
post #4 of 15 Old 11-17-2018, 06:52 AM
Hogges's Avatar
Donít know the product you are talking about but there are plenty of offerings and they obviously all do the same thing. I chose the Ravetech ones (eBay or direct through their website) because they are made of solid stainless steel. Some people had their aftermarket aluminum links wear out on them over time. OEM is steel.
Hogges is offline
post #5 of 15 Old 11-17-2018, 09:05 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
OEM is zinc plated stamped mild steel.
The aluminum links that wore out were cheap 6061-T6 off of Ebay. 6061-T6 is a great material, but is not as strong as steel in the same dimensions. The people selling these links knew that they were not as strong as stock and marketed them as light duty. They went out of business soon after.
Ours are 7075-T6 which is stronger than most steels in the same dimensions. In ten years we have NEVER had a link fail and fully expect to never have one fail.
Our links are available from 1/2" to 1.125" in 1/8 inch increments.
I recommend that you place boards of different thicknesses next to you bike to simulate different amounts of lowering and then lower the bike minimum necessary to make you comfortable. Many people have been surprised at how little is needed do make the confidant and comfortable. As changing the height changes how well the side stand and center stand work you will want to make as little change as needed.
3/4" up or down is the sweet spot for maximum change without feeling like you need to modify the stands.
Gen 1 and 2 DL650 and Gen 1 DL1000 - AdventureTech, LLC.
chirosyd and Rum Runner like this.
richlandrick is offline
post #6 of 15 Old 11-17-2018, 09:28 AM
I got mine from Richland rick. Quality product and priced right. Also, He's one of us. I support him.
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these tings to other people and I require the same from them."
John Bernard Books The Shoootist
JWnWyoming is offline
post #7 of 15 Old 11-17-2018, 12:21 PM
Mucksavage's Avatar
I have a pair of 3/4" lowering links that I took of my '12 650. If you find they are a matching cross reference they're yours for the price of shipping!
'12 Glee, Metallic Fox Orange, '98 DR350, CMA #183680
Mucksavage is online now
post #8 of 15 Old 11-18-2018, 09:17 AM Thread Starter
Rum Runner's Avatar
Good to know about Adventure Tech, that may be the direction I'll be going. And thanks for the generous offer Mucksavage. I'm going to make the decision after I get my break in miles in. Still need a chance to bond with the new bike and feel it out. My go to would have been Pro Cycle based out of Eugene, Oregon, but I see they don't offer links for my year. I have Adventure Tech link saved, thanks richlandrick think I may soon be a supporter as well. Thanks DonOhio I didn't think about making my own, good info and it wouldn't cost me a dime will the resources I have at work.
post #9 of 15 Old 11-18-2018, 10:40 AM
Originally Posted by Rum Runner View Post
...but I see they don't offer links for my year.
All 650 model years use the same links. 650 links are also the same as the 1000 links from '02 - '12.
post #10 of 15 Old 11-18-2018, 11:58 AM Thread Starter
Rum Runner's Avatar
https://procycle.us
Pro Cycle doesn't seem to carry links for 2014 and above. Its odd they would not list the 2017 link if they are all.the same but it's good to know thanks.
Raising and Lowering Links richlandrick AdventureTech LLC 66 03-03-2019 11:36 AM
Chain Slack with Raising Lowering Links richlandrick General V-Strom Discussion 0 08-14-2015 10:19 AM
Soupy's adjustable lowering links Macdoc DL650 and DL650A - 2004 to 2011 3 11-30-2014 08:46 AM
