Farkle list and upcoming Mexico Trip - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 56Likes
post #1 of 88 Old 11-14-2018, 02:06 AM Thread Starter
WingVetteStrom's Avatar
Got a 1 week old 2018 650XT. Here's the farkles on order, and in addition I pulled the seat, removed the 4 rubber bumpers, and wrapped the two seat "tongs" that fit under the tank with duct tape and it fits in nice and snug, lowering the seat by about 3/4" (1/2" bumpers plus approx. thickness of tape wrap.) Not a lot, but with a 30" inseam everything helps. I really like this seat so keeping it.
Getting ready for a 6 week trip to Morelia, Mexico from up hear near Seattle in Jan/Feb. Will comment on the individual farkles as I get them installed.
Anyone know where I can search for front axle sliders? Not much luck.
FYI, I just sold a farkled out 2018 Tiger 800 for this. Reasons if you're curious.
• Pivot Levers (So can keep OEM handguards.)
• Admore Flashing Brake, Progressive Turn Signals, and Decel. Lighting
• SW-Motech Crashbars
• SW-Motech Centerstand
• SW-Motech Adjustable Wide Street/Off-Road foot pegs
• Givi PLR Side Racks
• Givi GRT709 35L Panniers
• Oxford Heated Grips
• Garmin 396LMT-S GPS with Tire Pressure Monitors- hard wired
• Front Fender Extender
• Front Fender Risers
• Crampbuster
• Headlight Protector
• Givi AF3112 Airflow 2-part Windscreen
• Puig Rear Spool Sliders
• ADVTech Skid Plate
• ADVTech GPS Dash Mount
• ADVTech Flood Lights
• ADVTech Fork Brace
• Zeta Offset Handlebar Risers
• Side Stand Foot
• Front Fork Covers- Home Made with 1/4" Neoprene and Velcro
• R&G Racing Rear Shock Cover
• R&G Racing Radiator Guard
• R&G Racing Tank Pads
• R&G Racing Filler Cap Trim
• Front Axle Tool
. Home made sheet metal plate under front fender for hiding radar detector with transmitter to heads up display in helmet- hard wired
. Switched Fuse block with Battery Tender switched connector
. Battery Tender Cable for charging and Gerbing Vest
Lrobby99 and Rollin' like this.
2018 V-Strom 650XT
2018 Goldwing Tour DCT
2015 Z51 Corvette Stingray
WingVetteStrom is offline
post #2 of 88 Old 11-16-2018, 08:06 PM
Would like to know how you plan to install controllers for heated grips, Gerbing gear, and auxiliary lighting. Have run into some issues with these farkles that has me stumped.
TCARS, y'all 2017 DL650 XT
Past rides: 2005 Vulcan 800 Classic, 1999 Concours (C-10)
Volcantour is offline
post #3 of 88 Old 11-17-2018, 12:22 AM Thread Starter
Gerbing Vest is a simple SAE to ring connection to the battery. When my fuse block arrives, I'll run it to that. Electrical connection has good fuse blocks, recommend the one that will take all three size fuses, and has a separate switched battery port. https://electricalconnection.com/ind...te-fuse-block/
Oxford grips I'll have to see about when they arrive. I'll pull the tank and maybe the airbag to run the wires. If the Oxford has a white connector that doesn't match with the bike, I'll probably buy one of these, or another one on the Eastern Beaver website that will work. https://www.easternbeaver.com/Main/B....html#new650aa
Adventure Tech's light setup comes with a plug and play harness it appears.
2017+ DL650 Auxiliary Lighting - AdventureTech, LLC.
Won't start the farkle project until everything arrives end of next week.
To the above list, I've added SW MotoTech Evo City Tank bag and ring and map case, Kaoko Throttle Lock, and Tank pads.
I'm pulling my hair out trying to find a folding gear shift lever and folding rear brake lever, so if anyone has a link to something would appreciate forwarding it. SW Motech has one but it won't be avail. until after I leave for my Mexico trip.
2018 V-Strom 650XT
post #4 of 88 Old 11-17-2018, 02:58 AM
Curious about airbag you will be removing. Also, would like to see a photo of the tank bag installed if convenient. I'm leaning towards the City bag as well.
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #5 of 88 Old 11-17-2018, 02:14 PM Thread Starter
Sorry, meant airbox. Will try to do an Evo pic in a couple weeks. Out of town next week.
2018 V-Strom 650XT
post #6 of 88 Old 11-29-2018, 04:52 PM Thread Starter
Here you go. I also purchased the map case.
2018 V-Strom 650XT
post #7 of 88 Old 11-29-2018, 05:09 PM
I wish you the very best of luck....
Why Mexico, aren't you the slightest bit worried about your personal well being?
DaveinNC likes this.
post #8 of 88 Old 11-29-2018, 06:37 PM
Thanks for the photos. Nice looking bag. Do the controls hit it on full lock? Does it touch the tank at all?
Bob S.
Previous loves:
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
Nicad is offline
post #9 of 88 Old 11-29-2018, 06:49 PM Thread Starter
Maybe a little, but I've ridden bikes in many places in South and Central America, and never once had any hint of a problem.
Just don't be an obnoxious gringo. :-O As they say in Spanish Tu solamente vive uno vez. You only live once.
Would you rather ride through Mexico or the South Side of Chicago?
Big B, Jarvis and Nicad like this.
2018 V-Strom 650XT
post #10 of 88 Old 11-29-2018, 06:53 PM Thread Starter
I set up the bag at the full aft position. The handlebars slightly push into the sides of the bag at full lock. More of an issue is a Ram Mount X Grip phone mount on the left side of the handlebar that will cause my phone to slightly push into the bag at full lock. But neither will prevent full lock on the bars.
But one observation is that the Quick Lock doesn't lock the tank bag very securely. A slight lifting upward on the front of the bag will cause it to unlatch. I'm going to have to tie a loose strap thru the handle and around the middle of the bars.
2018 V-Strom 650XT
