Bar risers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 28 Old 11-09-2018, 12:47 AM Thread Starter
WingVetteStrom's Avatar
Bar risers
Just took possession of a 2018 650XT. Need bar risers/risers that move the handle bar backwards somewhat. All the cables look like there's hardly any slack. Has anyone installed bar risers on a 2017/2018 without having any difficulties with cable length.
thx....
2018 V-Strom 650XT
2018 Goldwing Tour DCT
2015 Z51 Corvette Stingray
WingVetteStrom is offline
post #2 of 28 Old 11-09-2018, 11:03 AM
You'll need to extend the brake lines and maybe reroute some other stuff. Adventure Tech sells a +2" upper brake line from Galfer for $58. Get this and you can keep your lower stock lines. If you want the full braided steel front brake line kit it's $112.
brock29609 is offline
post #3 of 28 Old 11-09-2018, 12:19 PM
eff
eff's Avatar
The Zeta 7/8" Offset Handlebar Risers should be good for you and not require replacing cables/brake lines. There are several threads on here commenting that they had no issues. I have been looking at these for myself and just need to pull the trigger.
https://www.amazon.com/dp/B071CX5L57..._hfC5BbGVHZH50
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #4 of 28 Old 11-09-2018, 01:52 PM Thread Starter
Would probably like to go more than a 26mm change. So no replacing of throttle or clutch cables? They look pretty tight as they are.
2018 V-Strom 650XT
post #5 of 28 Old 11-09-2018, 01:57 PM Thread Starter
thx guys!!
2018 V-Strom 650XT
post #6 of 28 Old 11-09-2018, 02:06 PM
All I know is previous owner of my '17 had SW-Motech risers on prior to selling me the bike (30mm up, 21mm back). He had +2" stainless brake lines on with stock throttle and clutch cables. I thought he mentioned that something was rerouted, but looking at the pics he posted in the classified ad I don't see evidence of rerouting. I had him put it all back to stock before shipping me the bike.
post #7 of 28 Old 11-11-2018, 12:16 AM
BKP
BKP's Avatar
I've got SW Motech 1" up and 1" back risers... Very pleased with the construction.
No problem w/ the cables, *however*:
1- I have +2" braided steel brake lines from AdventureTech (Gaffer)
2- I also lowered the bike (both rear and front end). That also adds just a bit of cable slack by bringing the bars a bit lower...
All that said, I don't believe adding the up and back risers would be a cable problem with the stock lines, if you release or stretch just one or two of the routing clips.
[B][I]Barry[/I]
2017 Pearl White 650[/B]
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #8 of 28 Old 11-11-2018, 08:58 AM
Rum Runner's Avatar
The Zeta should be just what I need. And no need to reroute cables or extend beak lines would be awesome. It's the first mod I need for my first Wee. 2017 650. Can't wait to get break in done and Mosko Moto bags on. Then it's And Awwwayyy WWeeee Go.
Rum Runner is offline
post #9 of 28 Old 11-11-2018, 12:36 PM Thread Starter
Off topic, but did you look at Givi GRT709 bags? I'm trying to decide between those and the Mosko Backcountry 35L's.
2018 V-Strom 650XT
post #10 of 28 Old 11-14-2018, 06:06 PM
Sullaha's Avatar
I used the Zeta 25mm up and 22mm offset and that's about as far as one could go safely with the standard lines and cables and bars.
'17 DL650A -bike # 30 something-
'91 Yamaha SR313 Tracker
'97 BMW F650 "Die Haifisch"
'19 Indian FTR 1200S (when it F#%king gets here!)
D.A.S.C for life!
Sullaha is offline
Installing a Scott's with risers, revisited DesertBike DL1000 from 2002-2012 26 10-16-2018 09:09 PM
Installing Rox AV Risers & Extended brake hose Green427 Maintenance, Tech and Products. 7 06-04-2018 06:56 PM
Risers again, but with safety in mind kman15 DL650A - 2012-2016 7 08-09-2013 11:49 AM
2' risers + pro tapers + break line = Possible CHINOTAKER DL650 and DL650A - 2004 to 2011 3 05-04-2012 01:34 AM
First Look: ROXĚs NEW Pro-Offset Elite block risers Mercenary V-Strom Modifications and Performance 17 10-06-2010 10:37 PM
