Antigravity Lithium Battery '17 vstrom 650xt - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 15 Old 10-24-2018, 05:04 PM Thread Starter
MyBlackVstromXT's Avatar
Replaced the OEM lead acid battery that came on 2017 Vsrtom 650XT with an Antigravity ATX-12-HD-RS High-Power Lithium RE-START Battery. Anexact fit for 2017 Vsrtom 650XT... $224.48 on Amazon... Two extra +/- electrodes allowed me to separate accessory cables from cables required to run bike... Weight = 2.5 LB
MyBlackVstromXT is offline
post #2 of 15 Old 10-24-2018, 05:31 PM
what amperage does it have. i was thinking about doing the same but the price is a bit to dear for a battery
''I give as god as I get!'' - UDO
Catalin Efrimescu is offline
post #3 of 15 Old 10-24-2018, 06:44 PM
Macdoc's Avatar
It will start like you've never experienced before.
iamsmiling likes this.
Canada 2018 CB500x >2009 CBF1000 sold • 10 Wee ABS sold • 09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR650 • 93 ST1100 sold •
Macdoc is offline
post #4 of 15 Old 10-24-2018, 07:12 PM
Brockie's Avatar
They may be great to lower your bike weight and C.O.G. but if and when the battery does go down you cannot push start the bike. A flat battery means no power to the electronics and fuel pump.
I'm thinking that a charged battery pack becomes a necessity.
I'll stick to my AGM battery, thanks very much.
richlandrick likes this.
Brockie is online now
post #5 of 15 Old 10-24-2018, 07:23 PM
Macdoc's Avatar
What!!!! - you can't bump start regardless with a completely dead battery and if there is enough charge left to get the basics working it will bump start with the lithium. You should be carrying a jump battery anyways for all sorts of other reasons.
On a fuel injected bike, you have you pressurize the fuel system, initiate the computer and sensors and have enough juice left over to fire the ignition system. If you have a dead battery, you aren’t going to be able to do all of this in the time you have to push start the bike, unless you have a very long hill to coast down in a tall gear. You would have to get the rear wheel to turn the engine long enough for the system generator to produce enough power to operate the fuel pump, computers, sensors and ignition system. Taking the fuses out for the lights would help and if you just have a weak battery, you might just get the job done.
4 years in and despite sitting for months the KLR starts instantly .....so did the CBF1000 - like it had never done with a standard battery.
Macdoc is offline
post #6 of 15 Old 10-25-2018, 03:58 AM
Jarvis's Avatar
In the past when I let an Lithium battery drain completely down (in this case it was a stuck radiator fan switch on my Beta) they are pretty much toast. I could not recharge after it was completely flat.
The other thing about Lithium batteries is they work very strange when the weather gets cold. They will barely turn over your bike for a little bit. But as you place load on them the chemistry begins to wake up and they start cranking better.
On my WR250R and KTM 450 EXC I run lithium batteries and so far no issues with the WRR. It will start right up after sitting for a long period as long as it is warm out. If it drops much under 35F then it needs a little coaxing. Haven't had the one installed on the KTM long enough to know how it will behave.
On my Ninja 650R and DL650 I tend to stick with an AGM battery since the weight savings for the price point just don't do much on a bigger bike for me. I can be a cheap bastard.
2018 DL650XT - Nomad
2012 WR250R - Rowen
2003 KTM 450 EXC - Hulk
Jarvis is offline
post #7 of 15 Old 10-25-2018, 06:25 AM
That sure is light. What does the stock battery weigh?
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #8 of 15 Old 10-25-2018, 08:56 AM
Oh man... ROTFL
Kerri Miller is offline
post #9 of 15 Old 10-25-2018, 10:17 AM
"should be carrying a jump battery anyways for all sorts of other reasons."
Yup an extra $60-$100 for the back up. There are still some good conventional lead-acid batteries on the shelves for less than $100.
It's an ADV bike laden with extra lengths of steel tubes and aluminum and plastic to take you where no man has gone before and there is concern about the extra few pounds a battery may weigh?
When you stop at the Subway for lunch, just get the 6" sandwich, skip the bag of chips!
Jarvis and snorkie like this.
post #10 of 15 Old 10-25-2018, 11:06 AM
If I were running a woods bike where weight was more critical I would certainly consider a Lithium battery.
On a DL 650 or 1000 the difference in weight simply cannot be noticed. Maybe a placebo effect if that.
As mentioned, cold weather can be problematic with lithium batteries.
Lead acid battery tech is way over a century old. Still around. Must be something that works!
Big B likes this.
realshelby is offline
Corroded negative battery cable bolt concern bikeflyer Testing grounds 0 06-28-2018 10:27 PM
Load testing your battery Rolex General V-Strom Discussion 22 11-25-2013 04:40 PM
My Vstrom DL1000 and Hannigan Dual Sport sidecar Outfit fotosaccion DL1000 from 2002-2012 16 04-13-2012 11:56 AM
