Anyone running an Eastern Beaver PC8? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 10-23-2018, 06:45 PM Thread Starter
I bought one with the VStrom harness, but cannot see any connector at the back to hook the trigger lead up to. I am thinking I have to disassemble the taillight to access a suitable connector? Any tips appreciated. Thanks.
Bob S.
2017 Vstrom 650 Base model (White)
2017 Yamaha YZ250X (Sold)....Hopefully WR250R soon
Previous loves:
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom out of town)
Nicad is offline
post #2 of 10 Old 10-23-2018, 09:05 PM
I have one on my V2. My connector is under the seat between the battery and gas tank under a rubber flap. Yours is a different model but might still be in the same general location. Just because itís a tail light connection does not necessarily mean the back of the bike. Good luck with the install
Houstrom46* is online now
post #3 of 10 Old 10-23-2018, 10:36 PM Thread Starter
Thanks, will keep looking.
Bob S.
Previous loves:
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
Nicad is offline
post #4 of 10 Old 10-23-2018, 10:50 PM
Brockie's Avatar
Pay attention to this part of Eastern Beavers instructions.
"SWITCHING LEAD: I connected the VStrom Kit’s switching lead to the rear brakelight connector shown below. Other Kits will have to connect the blue Posi-Tap to a switched hot wire on the bike. You can use the tail light wire, a pilot light, or a wire feeding a brakelight switch as on the VStrom."
More info at: https://easternbeaver.com/Main/Wirin...tallation.html
You can use the heated grips circuit, or any other switched connection on the bike.
Edit: You do not have to disassemble the tail light. Just use a wiring diagram or trial and error to locate the switched wire going to the tail light.
Brockie is offline
post #5 of 10 Old 10-23-2018, 11:27 PM
Brockie's Avatar
The heated grips connector is a two pin plug with a Green/white stripe wire, and a Black/white stripe wire. It is found under the tank by the radiator.
Otherwise look for a Brown wire which turns to Green at the 5 wire plug that goes to the tail light, and the Black/White stripe earth.
Brockie is offline
post #6 of 10 Old 10-24-2018, 07:43 AM Thread Starter
, They must have changed the rear light wiring on the 2017. I did see the brake light switch coming off the rear brake, but assumed it would only be energized when the brake was on....guess it is hot with the ignition and switched through the ground wire. Will try that. Thanks a lot.
Bob S.
Previous loves:
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
Nicad is offline
post #7 of 10 Old 10-24-2018, 08:46 AM
I'm don't know where the brake light connector is on the 17+ DL650, but if you look carefully on the Easter Beaver site, he has a different kind of adapter for the 17+ DLs for the PC8 than for earlier models. Apparently different type of connectors. EB has a linked section under the VStrom bike specific product for NEW DL1000s/NEW DL650s. Make sure you have the adapter listed there.
speedy7 is offline
post #8 of 10 Old 10-24-2018, 09:08 AM Thread Starter
I should read more before posting questions!....noticed he used the rear brake line connector on his Vstrom. The way it is zip tied together suggests that the lead wants to go to the back of the bike with the PC-8. The brake switch connector is towards the front of the bike near the pedal. Looks like there is enough wire to fit though.
Bob S.
Previous loves:
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
Nicad is offline
post #9 of 10 Old 11-11-2018, 07:39 PM
***disregard, I found the connector. It was a little buried by I got it.
Nicad, were you able to install the PC-8 with the supplies brake light lead? I received mine and am wondering which connector this is. Did you have to pull the tank to get to it?
2018 V-Strom 650 XT - Champion Yellow
Rustlr63 is offline
post #10 of 10 Old 11-11-2018, 11:49 PM Thread Starter
No, the connector you need to tap into is a little bit above the brake pedal. Really nice product. The only thing I'm altering is replacing the screws that hold the cover on with knurled thumbscrews I sourced on Ebay.. I used 3M dual lock tape to hold the PC8 down behind the tool storage. I have ten feet of the stuff if you want some.
Bob S.
Previous loves:
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
Nicad is offline
Installing Eastern Beaver Handlebar Wiring Extensions WeePilot DL650A - 2012-2016 12 04-21-2015 06:46 AM
Eastern Beaver and Twisted Throttle eaglefrq General V-Strom Discussion 3 10-16-2012 09:38 PM
Eastern Beaver - Opinions Needed of my plan Strange Dog Techy World! GPS, Electronics, etc 4 10-10-2012 02:51 PM
