gps power - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 17 Old 10-18-2018, 11:53 PM Thread Starter
power to gps
I have had a 2017 650 XT for three days and managed two laps of the Old Road to wear off the tyre tits. But the manual states that the 12V power socket on the dashboard should only be used to charge cellphones. How do I power a Zumo GPS - It used to be wired directly to the battery on my (sold) 1200GS. Ubique.
Everywhere is offline
post #2 of 17 Old 10-19-2018, 12:07 AM Thread Starter
gps power
I have had a 2017 650 XT for three days and have managed two laps of the Old Road to wear the tits off the tyres. First question of many - the manual states the 12V socket on the dash must only be used to power mobile phones. How do I power my Zumo which used to be directly hooked to the battery on my (now sold) 1200GS and which works perfectly plugged into the phone socket of my four-wheeler? Ubique.
post #3 of 17 Old 10-19-2018, 12:27 AM
V2man's Avatar
Try this https://www.stromtrooper.com/dl650a-...connector.html
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #4 of 17 Old 10-19-2018, 12:28 AM
drrod's Avatar
Why not just plug it into the 12V socket. I have powered Tomtoms and various garmin units from the 12V socket. Should not be an issue especially since it works with your 4 wheeler.
drrod is offline
post #5 of 17 Old 10-19-2018, 01:43 AM
RCinNC's Avatar
It's not limited to cell phones, but it is limited to the amount of current you can draw through the outlet. How many amps does a Zumo use when it's powered up? If it's lower than the capacity of the outlet, then you can plug in your Zumo. The outlet is 12 volts, if it's a standard cigarette lighter style outlet; if I had to guess, I'd say it has a 3 amp capacity, but I could be wrong about that.
There are different ways of running power to your Zumo, depending on where you want to mount it. You can run a power cable off the battery (with an inline fuse for the wiring) terminating in a handlebar mounted outlet that's rated for the amperage needed for your Zumo. The handlebar outlet works good if you're going to mount the Zumo on the bars. Where were you planning on mounting it?
Big B likes this.
RCinNC is online now
post #6 of 17 Old 10-19-2018, 01:48 AM
Brockie's Avatar
I can only presume that the intention is to inform you that the socket should only be used for low draw items, not things like heated grips and gloves.
Phones and GPS's are low draw items. Plug it in.
Big B and VSrider like this.
Brockie is offline
post #7 of 17 Old 10-19-2018, 02:05 AM
p38arover's Avatar
Threads merged, also not a Australia-NZ specific question. Please don't post the same question in multiple areas.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #8 of 17 Old 10-19-2018, 09:20 AM
V-Tom's Avatar
You are better off running the (fused) power line directly to the battery or from a Fusebox. The Zumo isn't designed to be powdered from a cigarette lighter plug.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #9 of 17 Old 10-19-2018, 09:38 AM
Hard wire it to the accessory socket wires. Since it's fused you can remove the inline fuse holder from your GPS cradle.
VSrider likes this.
brock29609 is offline
post #10 of 17 Old 10-19-2018, 10:56 AM
drrod's Avatar
..Tom
Garmin sells a cigarette plug powering device for Zumos.
https://buy.garmin.com/en-CA/CA/p/pn...838-00#devices
Garmin 12 volt adapter for StreetPilot c500 and nuvi series (010-10747-03) - GPSCentral.ca
What harm does it do to use one if it is not designed as such? I have seen many Zumo units run off of cigarette plugs because they are moved from vehicle to vehicle and, to my knowledge, the failure rate is no different than those run on dedicated hook ups.
Macdoc likes this.
drrod is offline
Weekend project - aux power Brojon DL650A - 2012-2016 1 05-02-2016 03:08 PM
Power Outlet Problem Jim Judd DL1000A - 2014-2016 8 03-22-2016 12:12 AM
Snaking power cable from GPS to Battery Harry Dresden PI DL650A - 2012-2016 7 02-16-2014 03:34 PM
Power Commander or re-gear? Power commander 3 or 5? Red5 DL1000 from 2002-2012 12 12-30-2013 07:53 PM
