Mounting OEM crash bars - howto - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By gary_lucas
  • 2 Post By notacop
post #1 of 2 Old 10-11-2018, 01:20 AM Thread Starter
I didn't see this anywhere, I searched quite a bit. This is a quick and dirty how-to for those of us who haven't done this kind of work before:
1) Instructions are 'good enough' but a bit vague, they don't tend towards description, just some graphics but they do get the job done.
2) The center bolt that goes through the engine, I'm not sure why it's there... But there doesn't seem to be any real stress on the bolt. Just put a breaker bar on each side and have at it... (Or in my case a small impact wrench).
Once the bolt is loose it just slides out. The engine did not fall on my foot
3) The smaller bolts on the upper forward section have some blue loc-tite, so prepare to use a fair bit of force. I ended up very carefully using my small impact to knock those loose.
I put the whole thing together barely tight... Then I loosened each bolt / nut up enough to apply loctite and then torqued to spec (over torqued in the case of the small bolts joining the bottom member as my torque wrench didn't go that low.. Hopefully that's fine. I may crack them off and put on fresh bolts one day.
The whole install took about 45 minutes with my 4 year old daughter helping me... And yah, she actually did help
Gary
notacop and Hatchi like this.
gary_lucas is offline
post #2 of 2 Old 10-11-2018, 09:27 AM
Hope you and daughter had a good learning lesson with the installation. Quality time.
Hatchi and gary_lucas like this.
Crash bars GregB DL650A - 2012-2016 3 06-19-2015 04:13 PM
enduro guardian skid plate with so motech crash bars work! ukele6 DL650 and DL650A - 2004 to 2011 4 10-15-2014 10:39 AM
Crash Bars and Skid Plates and Center Stands, Oh My! RobG DL650A - 2012-2016 5 07-08-2013 04:19 PM
Crash Bars/Skid Plates- Q&A - all you could ask and then some Skinnifatkid General V-Strom Discussion 11 05-29-2010 12:46 PM
