Doctor Vstrom 3rd Gen Videos: Chain Adjustment & Alignment, Detailed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Vstormer77
  • 1 Post By brock29609
post #1 of 2 Old 10-10-2018, 08:24 AM Thread Starter
New Vid
https://youtu.be/TJi4f6FUH-I
gary_lucas likes this.
Vstormer77 is offline
post #2 of 2 Old 10-10-2018, 12:54 PM
You should measure chain slack by the amount it moves perpendicular to the chain, not vertically from the ground. The tape measure should be at an angle.
I keep some small round magnets stuck to the side of my frame. I stick them on the chain to indicate the tightest spot. You just have to remember to remove them from the chain once done. I also put a small vinyl decal on the swing arm to indicate chain mid-point so I don't have to remeasure each time.
The magnets are also great when lubing chain to indicate your starting/ending point as you're spinning the wheel and spraying lube.
Kurtk likes this.
brock29609 is offline
Chain and Sprocket Combinations with RK Chain and Press Fit Rivet Tool SV Racing Parts SV Racing Parts 104 07-14-2017 11:12 AM
Chain slack adjustment Patico DL1000A - 2014-2016 19 01-05-2015 08:30 AM
Drive chain - musings and questions Strange Dog DL1000 from 2002-2012 28 02-14-2014 12:31 AM
Chain / Sprocket alignment rhbell V-Strom Service and Maintenance Questions and Discussions 11 07-02-2008 11:32 AM
