Rigid auxiliary lights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By brock29609
  • 3 Post By Yarz1
post #1 of 8 Old 09-23-2018, 05:11 PM Thread Starter
I have some Rigid industries D2's on my car and I find the performance and build quality fantastic. Contemplating what additional lights to put on my bike and open to suggestions. Was considering these:
https://www.rigidindustries.com/igni...t-ignite.html#
I'd like them to work as additional lights to help me be seen around town and then hopefully help light up the side of the road when I am in the country. The D2's are a bit bigger than I would like on the Vstrom and they do not have a low setting.
If you have anything you like and mounting suggestions, please chime in. I do not wish to put crash bars on my bike.
Tia.
Nicad is offline
post #2 of 8 Old 09-23-2018, 07:11 PM
scab's Avatar
I'm interested in what you come up with on these lights. I had the D2's on my watch list for a while but I didn't like the size for a motorcycle. Reading the description on the link you provided, I'm not sure that I understand the mounting options with these lights. Maybe the more knowledgeable will chime in.
edit: On a side note, back in the early days of crappy box-store LED's, I removed the front fork reflectors and mounted a set of said crappy LED's to the reflector bracket. The brackets held up to the weight much better than I anticipated. I eventually scrapped the lights due to the fact that they really didn't illuminate anything. The brackets did fine though, with no cracking from vibration-induced fatigued that I was expecting. They were probably on the bike 10-15 thousand miles. It was an FZ6 so no off-roading was ever considered.
If you're not living on the edge, you're taking up too much space.
scab is offline
post #3 of 8 Old 09-23-2018, 08:38 PM
I love mine mounted here. The aim hasn't budged at all since I mounted them 1,500 miles ago.
scab likes this.
brock29609 is offline
post #4 of 8 Old 09-23-2018, 08:41 PM
scab's Avatar
Argh! The photo isn't showing!
scab is offline
post #5 of 8 Old 09-23-2018, 08:58 PM
Originally Posted by Nicad View Post
I have some Rigid industries D2's.... Contemplating what additional lights to put on my bike and open to suggestions. ......as additional lights to help me be seen around town and then hopefully help light up the side of the road when I am in the country.
Nicad - those look like nice lights. Rigid does make good stuff. I didn't want to invest that much, so from another posting here about yellow fog lights, I pick up some bright and inexpensive fogs. A few years ago I hung "driving lights" from my hand grips. I used a pulse width modulator to tone them down to about 20% -- slightly dimmer than my low beams. I wired them up so that using two switches I can run them 20% and not blind anyone or using the other switch and bypass the PWM for 100% when no one is around. They help me see at night but I'm not sure they help me get seen in the daytime. So I bought the yellow fog LEDs and hung them on my forks. The bracket that I made uses the fender bolt and the reflector bolt for attaching. Both the upper driving lights and the lower fog lights turn when the forks turn. The headlights always point straight ahead. White lights across the top and yellow across the bottom.
SuperG, Nicad and scab like this.
Yarz1 is offline
post #6 of 8 Old 09-24-2018, 01:43 PM
It is now. Not sure what the problem was.
post #7 of 8 Old 09-24-2018, 03:56 PM
PerazziMx14's Avatar
Not wanting to dump an bunch of money into LED lights to replace a set of aging Hella incandescent fog light on the BMW I opted for a a set of Tractor Supply Traveller 3" 1200 lumen cubes. $54.99 per set and warranted for a year. I am very pleased with them.
PerazziMx14 is online now
post #8 of 8 Old 04-16-2019, 04:12 PM
BigSky's Avatar
PerazziMx14, any chance you have a couple of pictures of those mounted on your bike? These appealed to me for a couple of reasons, not the least of which are: a) I can get them locally; and, b) they have Cree lights in them.
BigSky is offline
Help with Auxiliary LED lights installation vroomer V-Strom Modifications and Performance 5 01-26-2017 10:51 AM
Yet another string of questions regarding auxiliary lights! Chaneera Maintenance, Tech and Products. 15 02-20-2016 03:28 PM
LED lights on my Vee Crew_Dawg_Dave V-Strom Modifications and Performance 0 05-04-2015 02:14 PM
Rigid Industries Dually D2 lights mounted wump DL650A - 2012-2016 7 10-29-2013 10:45 AM
My Glenda and Krista Clearwater Lights mbrinitzer Techy World! GPS, Electronics, etc 6 06-12-2010 03:01 AM
