brake light switch adjustment, rear brake? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-02-2012, 06:52 PM Thread Starter
Is there a way to adjust the switch for the rear brake light?
I was messing with the rear brake where it attaches to the foot pedal to get some of the play out from when I touch the pedal to when the brakes are being applied. I got them how I want them, but now the brake light is always on. Is there a way to adjust the position of the switch (I am not even sure where it is), so that I gan get the pedal to engage where I would like it?
Thank you.
2012 DL650AL2
glass3222 is offline
post #2 of 7 Old 09-02-2012, 07:05 PM
The switch is adjustable. It's at the top of the spring that connects to the rear brake pedal.
post #3 of 7 Old 09-02-2012, 07:07 PM Thread Starter
Thanks greywolf, is this what I adjust, or it is behind the bracket?
2012 DL650AL2
post #4 of 7 Old 09-03-2012, 01:26 AM
That's the one. The plastic nut at the bottom is the adjuster.
Don't rotate the wiring.
Peter
PeteW is online now
post #5 of 7 Old 09-03-2012, 11:17 AM
You can lift the switch a little to relieve pressure on the nut and turn the plastic nut with your fingers to the right to lower the switch body. No tools are needed.
post #6 of 7 Old 09-03-2012, 11:20 AM Thread Starter
Thanks guys, I got it all adjusted how I want it now.
2012 DL650AL2
post #7 of 7 Old 07-25-2014, 02:02 PM
Kcwiro's Avatar
Excellent...
This stopped working on me and turns out it was just way out of adjustment... thanks
-Scott
2009 WEEStrom ABS - ~56K and still ticking - rehoned head at 35k after double stacking a o-ring on the oil filter caused engine to relive itself...
1980 GS750E (first bike)
Kcwiro is offline
