Name and shame the designer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 08-31-2012, 01:16 AM Thread Starter
The bloke that designed the little square plastic tubes that stop the captive nuts turning in the front mud guard must one roo short in the top 40.
What a PITA.
Suzukis super dooper you beaut ultimate strength loctite on bolts with captive nuts held by .000001mm of plastic .What the ----------------
Had to be the same bloke that designed the new fairing/plastics attachment points,he should be stood against the wall and pelted with the bits untill he apologises
maccaoz is offline
post #2 of 10 Old 08-31-2012, 01:34 AM
The captive tapped rectangle also exists on the older bikes. The dumb move was putting high strength thread locker there. It's in many places it isn't needed.
post #3 of 10 Old 08-31-2012, 02:07 AM Thread Starter
They still haven't learnt.That makes it even worse.
I hate this stuff,gunner buy a Safari tank for the KLR so I can get at the working bits easy.(and have a decent fuel range:mrgreen
maccaoz is offline
post #4 of 10 Old 08-31-2012, 09:10 AM
D.T.'s Avatar
Thumbs down
Taking off the front wheel off helps win the battle.
I used grease on the bolts and they haven't came loose yet, so what the F is the deal with the super lock tite??
D.T. is offline
post #5 of 10 Old 08-31-2012, 10:23 AM
"I used grease on the bolts and they haven't came loose yet, so what the F is the deal with the super lock tite??'
I cringe every time I see locktite in these postings. That stuff has it's place in the world and most peoples hands is not it. Only a drop or two is needed and only when you really don't ever want the bolt undone again.
The only bike I had anything fall of was my '55 Ariel Huntmaster twin. Everything British of that vintage would shed pieces.
post #6 of 10 Old 09-01-2012, 01:23 AM
I had to remove the 2 kickstand bracket bolts to install a new belly pan on my new Gle...er...Wee. You guessed it; threadlocker. It was yellow looking. I expected red as hard as they were to loosen
deuce is offline
post #7 of 10 Old 09-01-2012, 01:59 AM
Suzuki uses a yellow/orange thread locker for its high strength work, not Loctite at all.
post #8 of 10 Old 09-01-2012, 03:06 AM
Do yourself a favour and use low strength thread locker for all the non-engine related DL parts.
It's not an American or Euro. bike, the vibration is low enough that low strength is enough for nearly everything that's likely to be removed
Pete
PeteW is offline
post #9 of 10 Old 09-01-2012, 07:01 PM
BSK
BSK's Avatar
Have you guys removed the licence plate light yet? The bolts are pressed into the plastic and break. Same stupid cheap design flaw.
Stephan
DL650AL02 -> Barkbuster handguards, 12V outlet, Lee Whitehurst luggage racks, JCWhitney Topcase, 3M reflective tape, P3 lights, 52w LED fogs, forkbrace, Puig 5895h windshield... more to come!
Failures:
Chain and sprockets worn at 9100 miles, recommended to be replaced despite every 500 mile adjustment and lube =(
Entire wiring harness replaced at 9233miles by SEP after headlight failure
Rear shock busted at 9727miles
Bad burned oil smell since 9500miles found to be disconnected drain tube from airfilter housing
2nd chain done at 21.6k
BSK is offline
post #10 of 10 Old 09-01-2012, 07:16 PM
Are you saying the #16 nuts are also thread lockered? When I took apart the bike to get it painted, I noticed a lot of thread locker where it wasn't needed.
