LED Brake light install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-30-2012, 09:51 AM Thread Starter
I am using an E3 very bright LED brake light from Strobe N More. I have read that the brake light is the brown one on the left hand side of the bike under the seat. But in searching this I found a white capped off connector coming out of the wire looming at that same spot. I guess I could search the service manual, but does anyone know what this one is? I know about the one behind the radiator (for heated grips) and the one under the right dash for accessory plug. But I've not read about this rather one.
JDP
jdpower is offline
post #2 of 3 Old 08-30-2012, 10:42 AM
The brake light wire is white with a black stripe. The brown wire is for the tail light and it changes to gray in the rear fender. Ground is black with a white stripe. The capped off connector is the dealer mode plug for the Suzuki diagnostic tool and checking error codes by jumper. http://www.vstrom.info/Smf/index.php/topic,7061.0.html
post #3 of 3 Old 08-30-2012, 10:49 AM Thread Starter
Great info. Thanks.
JDP
jdpower is offline
