Help needed: OEM Aluminum Top case - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-29-2012, 10:20 AM Thread Starter
Could someone that has the OEM aluminum top case be kind enough to post a picture of the attachment plate (bottom of the case)? I am thinking about making my own using aluminum sheet and then mount it on a pelican case but I need a template. I would then buy the top case installation kit (990D0-11J00-062) and I should be able to use it on my 2012 adventure.
Thanks in advance!
nster is offline
post #2 of 5 Old 09-01-2012, 04:01 PM Thread Starter
Anyone?
Anyone?
Thanks
nster is offline
post #3 of 5 Old 09-02-2012, 03:53 PM
mountainpete's Avatar
For your viewing pleasure.
Plastic mount on the top right is for a rear-facing GoPro camera.
That's not a crack - I checked carefully. It's a strangely located scratch.
Tape on the base plate is my ghetto way of eliminating vibrations - simple and it works:
2012 DL650 EXP
Designed for outdoor use
mountainpete is offline
post #4 of 5 Old 09-02-2012, 04:20 PM Thread Starter
thanks!
Hi MountainPete
Thanks for taking the time posting these pictures. I appreciate that.
Take care.
nster is offline
post #5 of 5 Old 09-02-2012, 04:22 PM
Anytime. Let me know if you need others
2012 DL650 EXP
