What does your temp. display typically show? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 08-28-2012, 02:52 PM Thread Starter
Lloyd's Avatar
Engine temp. I meant. Mine has always run at three bars (once warmed up and on the road).
[FONT="Comic Sans MS"]"Life is what happens to you while you're busy making other plans"[/FONT]
Lloyd is offline
post #2 of 17 Old 08-28-2012, 03:43 PM
Exactly the same.
_____________________
Regards, MillCreek
Snohomish County, Washington USA
2012 Suzuki DL650A
Three road, two mountain and one folding bicycle
MillCreek is offline
post #3 of 17 Old 08-28-2012, 03:56 PM
Don_T's Avatar
Hot or cold weather going slow or fast - always three bars.
Yamaha XT1200Z '15 - www.bike-addict.dk - It's not what you ride but how you ride it unk:
Don_T is offline
post #4 of 17 Old 08-28-2012, 04:00 PM
mojo34's Avatar
Always 3 bars
No matter how many hours, and regardless of the temperature, I've always got 3 bars after about 3-4 minutes.
"The rise in popularity of reality shows has brought people to live experiences second-hand in a context that involves no adventure, no danger... Whereas the road takes you out into the world."
- Walter Salles, about On the Road
mojo34 is offline
post #5 of 17 Old 08-28-2012, 04:15 PM
It may sometimes show two bars in cold weather or cool and rainy weather if it's like the Wee. Otherwise, it should always stop at three. With the oil/coolant heat exchanger, the Glee's temperature control is excellent.
post #6 of 17 Old 08-28-2012, 05:23 PM
Don_T's Avatar
Greywolf, as the Strom expert you might be able to answer this:
What temperatur range does the 3rd bar cover - my guess would be from approximately 176 to 215..?
Don_T is offline
post #7 of 17 Old 08-28-2012, 05:37 PM
Trailslapper's Avatar
3 bars,
hot or cold weather
fast or slow,
always 3 bars for me
Trailslapper is offline
post #8 of 17 Old 08-28-2012, 05:43 PM
D.T.'s Avatar
The service manual may say exactly what temp the coolant is at with 3 bars. You could try a non contact thermometer too, they are getting cheaper all the time.
My SV has a direct degree F temperature display, no bars. It usually runs around 185 degrees F.
D.T. is offline
post #9 of 17 Old 08-28-2012, 06:16 PM
Here. You figure it out. I went cross-eyed.
post #10 of 17 Old 08-28-2012, 06:47 PM Thread Starter
Lloyd's Avatar
If I'm reading it right, the 3rd bar indicates a temp. range of 158F - 228F. I'm not sure about the Ohms indication connection. (increased temp, decreased resistance??)
Lloyd is offline
