2012 'penny' seat mod - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 08-28-2012, 06:17 AM Thread Starter
Found another gel keyboard wrist rest lying around at work today. (Cover was torn, just sitting there in the trash waiting for death ... ).
Strip it down so I only have the gel, cut it in half. Pull the staples out of the seat to about half way back, peel up the cover, peel up the foam, insert the two gel strips between foam and seat pan, button back down.
Ahhhh - perfect. Because the seat shape has changed this works even better than it did on my K6 - flattens the seat out beautifully. Seat lifts about 1/2", but is now "many hours comfortable" - did an hour ride tonight deliberately not moving around on the seat - zero problems. The L2 seat is O.K. - much better than my K6 seat was stock but I normally do have to move around every five minutes or so to avoid 'numb butt'.
If you can't find an old keyboard wrist rest to put out of it's misery, you can buy gel seat pads on ebay (kno place) , these are supposed to go on top but if you slip it under the foam it's a really simple job - you'd only need the small one, cut it in half lengthways and position it so it's as near the edges of the seat base as you can get it. Plus there are no problems with the gel heating up sitting in hot sun if it's under the stock foam.
Pete
PeteW is online now
post #2 of 21 Old 08-28-2012, 08:53 AM
Byronw's Avatar
great idea, I'm guessing you lay the gel laterally, sideways along the edge of the seat ? does that leave a channel in the middle, or fill the entire area under the foam?
Byronw is offline
post #3 of 21 Old 08-28-2012, 09:00 AM
Good idea. This is great for many of us who work in offices where these are readily available. Any pictures of the process or the seat after the install?
Sent from my Galaxy Nexus using Motorcycle.com Free App
2012 WeeStrom
1994 DR650
phil4822 is offline
post #4 of 21 Old 08-28-2012, 09:20 AM
D.T.'s Avatar
Thumbs up
These are the mods I like, cheap! Just some labor involved.
I just use a black toilet floor mat on my seat, around $10 bucks.
D.T. is online now
post #5 of 21 Old 08-28-2012, 11:27 PM Thread Starter
No pics of the job in progress sorry, I needed three hands to hold the seat and use the stapler as it was.
I can take a pic of the finished seat, but unless you saw it side by side with the stocker you'd never pick it anyway - maybe notice it looks a bit flatter is all. That's the really nice thing about this mod - the seat maybe looks a bit taller and flatter and feels a bit firmer when you first sit on it, but there are no major appearance changes.
I cut the gel in half, so two half length pieces each about the length of the seating area, they go in lengthwise, just inside the lumps of foam that 'lock' the foam to the seat base. Front of the slabs was just on the holes for the front seat bumpers.
So yes, there's a soft spot in the middle which helps with the comfort - but that's not noticeable unless you push down on the seat with your hand - or you get real excited about your motorcycling I guess . There's also a slight soft spot if I sit waaay back as the gel ends just before the rise to the pillion seat starts - which works anyway as that's where my tailbone is.
Pete
PeteW is online now
post #6 of 21 Old 08-29-2012, 09:08 AM
Byronw's Avatar
Thanks for clarifying that, sounds like something I'll be looking to do. I put 3200 miles on the stock seat in a week last month, and it was OK, not as good as the suzuki gel seat I had on the old dl1000, but not bad enough for me to spend hundreds of $$ on a aftermarket seat. This may be all I need.
Byronw is offline
post #7 of 21 Old 09-09-2012, 10:16 AM
Byronw's Avatar
I peeled back the seat cover yesterday and installed an old gel wrist rest I found lying around. The hardest thing about this was stapling the cover back on. I have both an electric stapler and Stanley hand stapler, using 1/4 inch staples, they have a tendancy to 'bounce" and not go in all the way into the plastic seat pan. The best luck I had was to push hard on the seat pan where I wanted to staple, right against the workbench, and with as much pressure as I could put against the electric stapler, they worked fairly well. I haven't had a chance to ride with it yet, but hope to go for a ride this afternoon to check it out. Sitting on it, I think I'll be happy with it, firmer, wider, and taller is all good for me. Thanks for the idea, inexpensive, and I can go back to original if I don't like it.
Byron
Byronw is offline
post #8 of 21 Old 09-09-2012, 10:30 AM
Lloyd's Avatar
Thanks for the pics, and thanks to the original poster. Looks like a great idea, recycling and improving the comfort level of the seat for an investment of time and some staples.
Please let us know how it rides! Thanks again...
[FONT="Comic Sans MS"]"Life is what happens to you while you're busy making other plans"[/FONT]
Lloyd is offline
post #9 of 21 Old 09-09-2012, 12:30 PM
So Byron, will hand stapler not work or did you just find in the end the electric stapler worked better? Also, IIRC, aren't stock staples larger than 1/4"? Just wondering if the standard hand stapler is heavy duty enough.
MotoWPK is offline
post #10 of 21 Old 09-09-2012, 12:41 PM
Great mod.....but wouldnt the gap between them cause a bit of a funny feeling on the buttocks?:mrgreen:
