Removing front Fender on 2012 Adventure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 08-26-2012, 01:57 PM Thread Starter
Hello,
In my attempt to remove the front fender, there is one fastener that holds a clip to to route cables/hoses. It is the upper right fork leg, and there is a captive nut I can't see or get to , to remove the fastner. When I try to remove it with my allen wrench, I can hear the captive nut or whatever it is, spinning in there and not biting so allow the fastener to spin out. Anyone else run into this or am I missing a procedure to remove this? Thanks.
OreDL650Adventure is offline
post #2 of 11 Old 08-26-2012, 02:47 PM
It's been mentioned often. Suzuki decided to use a strong thread locker on a nut that is pretty much impossible to hold with a tool. The wheel probably needs to come off first. Then great care is required to use heat and/or anaerobic adhesive solvent to defeat the thread locker and not melt the plastic. That is best done before the backing plate spins in the fender.
post #3 of 11 Old 08-26-2012, 05:50 PM
Royal PITA, I had to take my front wheel off to fix.
JSPEED is offline
post #4 of 11 Old 08-26-2012, 06:11 PM
HotPockets's Avatar
Maybe try some pbblast? careful not to get it on brake lines or tires!
Sent from my DROID RAZR using Motorcycle.com Free App
'07 Yamaha Vstar 650 (sold)
'09 Honda CBR600RR (sold)
'12 WEEEEEEEstrom :biggrinjester:
'13 Yamaha FZ8
HotPockets is offline
post #5 of 11 Old 08-26-2012, 06:27 PM
TwoShots's Avatar
A tall, thin needle nose plier can be worked into place to prevent the nut from spinning. Awkward, but doable.
[IMG]http://kolobwebstudio.com/myimages/strom_liquid_jesus.png[/IMG]
TwoShots is offline
post #6 of 11 Old 08-27-2012, 04:32 PM Thread Starter
Fasterner spec
Does anyone know the fastener spec for that? (I kind of drilled mine out)
I want to make a different system that is temporary before I get the Touratech fender. I need size, etc. Thanks all.
post #7 of 11 Old 08-27-2012, 04:40 PM
It's a rectangular steel plate with a boss welded on that's drilled and tapped M6x1.0 and slid into a slot cast into the fender. If you haven't terribly buggered the hole, a 6mm nylock nut and a fender washer will work temporarily. What exactly do you need? If you drilled through the plate, you can probably use a longer bolt and nut with it.
post #8 of 11 Old 08-27-2012, 07:33 PM Thread Starter
Need bolt
Sorry, I only drilled out the Bold Allen head, then deeper into the bolt until it freed the fender. The square fastener is fine, but I am going to replace it with a locking nut/washer combo for sure. I need to bolt size. I did not hog out the opening at all, and was very careful.
post #9 of 11 Old 08-27-2012, 07:41 PM
Loosened both sides on mine a couple or weeks ago--what a pita to tighten back up. Yep-spun both sides loose. Got a small flat screwdriver up between the fender and tire to catch the nut ( or whatever Suzuki calls it ) and got them both retightened. Will replace both with locknuts when the front wheel comes off.
Turned a 15 minute job into a solid hour worth of cussing.
phoneman is offline
post #10 of 11 Old 08-27-2012, 07:46 PM Thread Starter
I thought it was easy too
Amen to that....
