Glee Lowering links Question! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 08-23-2012, 06:02 PM Thread Starter
Vinnie Strombolie's Avatar
Trying to lower my 2012 Glee--before I get into any more specifics, I have a quick question: to lower the bike should the new dogbones be longer or shorter than the stock?
Vinnie Strombolie is offline
post #2 of 12 Old 08-23-2012, 06:15 PM
Longer. For every one mm longer than the stock 140mm, the seat is lowered about 2.8mm.
post #3 of 12 Old 08-23-2012, 07:41 PM Thread Starter
Yep, thanks greywolf--I figured it out; it's counter-intuitive. Do I need to use a torque wrench to retighten nuts.bolts?
post #4 of 12 Old 08-23-2012, 08:51 PM
You know how educated your arm is better than I do. It's up to you.
post #5 of 12 Old 08-23-2012, 09:42 PM Thread Starter
Wil I die if I don't use Loctite?
post #6 of 12 Old 08-23-2012, 09:45 PM
They are locking nuts. One more question before you put your hands on it and you may die.
post #7 of 12 Old 08-23-2012, 09:48 PM
not sure the US spec, but on my Australian delivered model the nut is a "jam nut" (is that the correct term) - i have undo and redo at least 10 times in the last 4 years with my suspension work - never have to lock-tite
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #8 of 12 Old 08-24-2012, 04:37 AM
lowering your strom ?
could someone please explain the advantages of lowering the v-strom
apart from the obvious ,short people being able to tip-toe terra firma.
do they handle better in the twisties? the trade-off being compromised clearance in the rough stuff.
borgmann is offline
post #9 of 12 Old 08-24-2012, 05:42 AM
i only have a 30inch inseam measuring crotch to bottom of feet. if i shift my bum to get one foot completely flat, the other one is hanging in the air. - i can barely all my toes down both feet. - my bike is effectively raised 5 mm in the front and 15mm in the back - flat footing is fairly over-rated - i lowered mine by 10mm at the rear tyre when i first have the bike. Causes all sorts of clearance issue.
A change of vstrom's attitude, either through lowering the front or raising the rear (or a combination) compare to stock gives better handling - and for pre L2 bikes, -hi speed stability up to a point.
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #10 of 12 Old 08-24-2012, 06:16 AM
kitesurfer's Avatar
if you lower, you should lower front and back the same amount. getting the front lower will feel more responsive but it will also be less stable...think sportbike here. many sport bikes need a steering stabilizer because of this maneuverability. tank slappers could become an issue with the lowered front. lowering the back and not the front will slow the steering..not sluggish, but kinda sluggish. lower the bike properly, but will also reduce clearance meaning pay attention to lean angles.
2012 DL650
U.S. NAVY, RETIRED
kitesurfer is offline
