Disable ABS? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 08-21-2012, 02:53 AM Thread Starter
Adventure Traveler
Kankujoe's Avatar
Disable ABS?
Has anyone come up with a way to easily and safely disable the ABS braking system for off-road & gravel riding?
Joe
2012 DL650-ADV (Black), 2013 DL650-EXP (White), 2013 Honda CRF250L, 2008 Yamaha TW200
IBA #55242, SS1000 x2, BB1500, SS2000, 50CC, National Parks Tour x5 w/ Silver & Gold, 4 Corners & Alaska, 48 plus one, Great Lakes.
Ad-ven-ture: 1. an undertaking involving risk, unforeseeable danger, or unexpected excitement. 2. an exciting or remarkable experience. Trav-ell-er: 1. one who seeks to experience their world. 2. one who seeks to be immersed in other cultures.
Kankujoe is offline
post #2 of 8 Old 08-21-2012, 08:19 AM
Mud Puddle's Avatar
Have you looked at Eastern Beaver? Jim is great, I've ordered almost everything he makes for the VStrom.
Here is a link to the ABS Switch adaptor. $16
Suzuki VStrom Electrics
Here is a link to the switch. $8, $10, or $12 depending on which one you want.
Switches for Motorcycle Electrics, cheap worldwide shipping.
Hope this helps.
09 "Wee"-Strom DL650 (Orange)
99 Harley-Davidson XL1200S
00 Bultaco
73 Bultaco Sherpa-T
Mud Puddle is offline
post #3 of 8 Old 08-21-2012, 08:38 AM
Pull the smaller ABS fuse.
Use an EB(closed for August) switch adapter and a high amp switch.
Use a switch with the "proper" method at VSRI that lets you restart ABS without turning off the ignition.
Don't bother. It's a better ABS that probably won't cause a problem. If you like locking the rear brake for control or slide outs, use one of the above methods, but if it's about to getting out of control, hit the kill switch.
post #4 of 8 Old 08-21-2012, 12:28 PM Thread Starter
Adventure Traveler
Kankujoe's Avatar
Thanks for the replies......
And especially for posting the links.
Joe
Kankujoe is offline
post #5 of 8 Old 08-21-2012, 07:50 PM
Proper ABS on/off switch
for the proper ABS switch - takes a bit more time and you need make one cut and 2 solder. but the only proper way.
I must admit, aside from testing, i have yet to find it necessary to do the switch off in the 25,000km i have it installed. I must not not good enough or ride hard enough on dirt to need it.
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #6 of 8 Old 08-22-2012, 08:03 AM
Mud Puddle's Avatar
How is that any different than the Eastern Beaver Kit? Less expensive maybe but it is more labor intensive. However, both do have the same function. The major advantage of the EB system is that you don't have to splice any wires just unplug a connector and plug the new ones in.
00 Bultaco
73 Bultaco Sherpa-T
post #7 of 8 Old 08-22-2012, 10:07 AM
To reinstate ABS on the EB kit, you have to switch it on plus turn the ignition switch off and on again. The "proper" switch turns it off and on without having to cycle the ignition switch.
post #8 of 8 Old 08-22-2012, 12:21 PM
Mud Puddle's Avatar
OK...I didn't understand that. Thanks for the info.
00 Bultaco
73 Bultaco Sherpa-T
