Rear cylinder exhaust bolts... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 08-20-2012, 10:25 PM Thread Starter
Ok guys. I've looked at the shop manual and the bike and who knows the EASY way to get at 'em for the 4,000 mile re-torque? No wonder I was putting off checking out the degree of difficulty.
Phil Hill is offline
post #2 of 10 Old 08-21-2012, 02:23 AM
Taking the rear shock out is easy if you have a centre stand. You still won't have a LOT of room, but that may offer the best chance. (Lube all the pivot bearings while you are there).
Havn't done that with the ABS unit in the way - with the non-ABS bikes that left lots of room.
Pete
PeteW is online now
post #3 of 10 Old 08-21-2012, 08:53 AM
I have yet to read of a single problem there. I would, and have, left it alone.
post #4 of 10 Old 08-21-2012, 09:02 AM
D.T.'s Avatar
Take the motor out, then it will be easy. :mrgreen:
I just looked, and I'd say a 6mm allen socket, 3/8" knuckle, foot long 3/8" extension for the ratchet or torque wrench. Looks fairly easy to get at on the chain side. The ABS valves are right there also.
Or a ball end 6mm allen key might reach in there.
Me thinks Suzuki put that red threadlock of death on those bolts too.
D.T. is offline
post #5 of 10 Old 08-21-2012, 11:33 AM Thread Starter
Favorite answer
I like the idea of leaving it alone and that coming from you and yer savvy carries some weight. Will check the front and if it is right then the rear will be left alone. Also will check for leakage from time to time. Thanks
post #6 of 10 Old 08-21-2012, 11:39 AM Thread Starter
Pete
I never leave home without the center stand. On the recommendation of the GW guy it shall be monitored and left alone and probably never loosen up. After further perusal I figure it can be reached with the right assemblage of play toys and appropriate grimaces but at this point it's time to quit worrying and ride ride ride.
post #7 of 10 Old 08-21-2012, 12:40 PM
2 Sense
My front bolts exhaust broke when I doing a different repair.
I wouldn't touch em less needed.
Current 2009 990 KTM ADV -R
2007 DR650
2004 DL1000 gone
2002 KTM EXC520
2000 KTM MXC300 gone
themastermike is offline
post #8 of 10 Old 08-21-2012, 03:23 PM Thread Starter
Not good. Guess it'll just be inspections... Maybe a little unhappy with the idea of broken exhaust bolts.
post #9 of 10 Old 08-21-2012, 07:14 PM
Sentinel's Avatar
If their tight and no exhaust is leaking then don't fix them! :mrgreen:
Sentinel is offline
post #10 of 10 Old 08-21-2012, 10:27 PM
D.T.'s Avatar
The stainless steel bolts are pretty flimsy. I removed the front ones already and got rid of the red threadlock. Then used anti seize on them to re install so they don't get sheared off for the next guy (or me :mrgreen.
D.T. is offline
