Ricor Intiminators on '12 650 V-Strom? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 08-19-2012, 08:30 AM Thread Starter
I have read a lot about this product. I would appreciate any insight(s) you might share if you have installed them on your bike.
Mr. Pete----->
aging hippie
mrpete64 is offline
post #2 of 14 Old 08-19-2012, 10:18 AM
zt0117's Avatar
I don't have them on the Vee, but they made a big improvement on my KLR. They seem so small and inconspicuous, but they actually work well. I got them several years back when they were new and Ricor had them for 50% off. I think the regular retail is pricey, but if you want to upgrade your front end, it's still a relatively inexpensive way to do it. These and a fork brace should make most folks happy.
zt0117 is offline
post #3 of 14 Old 08-19-2012, 10:42 AM
tmcgee's Avatar
I moved them from my '07 to my '12. Well worth the price.
Everything you need to know was neatly summarized by AceRider here:
intiminator-summary-mods-make-work-great
tmcgee is offline
post #4 of 14 Old 08-19-2012, 12:08 PM Thread Starter
front end shock?
I am interested in how much of "zap" is gone when one rides over ridges on roads...like interstate highways.
Mr. Pete----->
aging hippie
mrpete64 is offline
post #5 of 14 Old 08-19-2012, 12:34 PM
tmcgee's Avatar
If you do everything that AceRider summarizes, they make the front suspension as good as it can get without going to Traxxion forks. There are long threads on both these and RaceTech valves on this forum. Bring a lunch if you intend to read them.
tmcgee is offline
post #6 of 14 Old 08-20-2012, 03:32 AM
Ordered and expect to have em in a few days.Going in using Ricor instructions only.Will be interesting to see how they preform with no other mods.They are excellent in my KLR.
maccaoz is offline
post #7 of 14 Old 01-27-2013, 02:03 AM
chrisbre's Avatar
very interested
Hi Maccaoz, I think you have an L2 -- so I am really interested to find how these Intiminator's work on your bike. I'm thinking seriously about them too.
The NSW roads are 3rd world standard (IMO), and I ride a bit of gravel - which of course includes corrugations.
Have you still got the stock rear shock fitted?
thanks
Oh -- I see I tagged along on an older post
and you have answered your above post at
https://www.stromtrooper.com/suspensi...k-great-3.html
chrisbre is offline
post #8 of 14 Old 01-27-2013, 02:10 AM
I installed them a week or so back. Didn't do anything other than remove all the fork oil I could from the top, drop the intiminators in, and replace the spacers with 25mm shorter PVC tube and top up with 5W Castrol fork oil. (My preload was about topped out before, 15mm would have put me where I was before).
They work brilliantly, perhaps a bit harsher on relatively smooth roads than the emulators in the front of my K6, but better off road. (Note that the L2 is better off road anyway). The nice thing is, the harder you push , the better they work. Really noticeable stability improvements under hard braking on road as well.
Note that they did 'soften' up a bit over a week or so, probably the seal bedding in, so don't 'fiddle' until you've run them for a while.
Pete
PeteW is online now
post #9 of 14 Old 01-27-2013, 06:12 AM
The shim stack they are shipped with these days are a lot better suited to vstrom than earlier days. PeterW, the harshness on smoother roads was the biggest adavantage your old tuned emulator has over the intinminator,,, the 1mm bypass holes "solve" that issue.
Not saying u need to do all the mods, but each one address a characteristic of the intiminator system- by all means just throw it in, ride a little then see which way u want to improve, and do the mod accordingly..
Good luck
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #10 of 14 Old 01-27-2013, 11:50 AM
Blackheart's Avatar
I really appreciate the improvement on my L2.
But, I think the rear Inertia valve on it is even better. I only rode it about 20 miles yesterday, but, I hit every pothole, chunk of rock, and rough transition joint that I could find. While I could still feel some of the hit through the front end, on many of those hits, the rear tire felt like it might have entirely missed the bad spot! I mean, it was even closer to a smooth Magic Carpet Ride than I expected, based upon my experience with several other products on different bikes, as well as the Inertia valve on a KLR and XLR I had on two previous bikes.
Blackheart is offline
