Grip puppies - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-16-2012, 07:05 PM Thread Starter
Grip puppies
Greetings fellow Glee riders! Just finished putting my first 500 miles on the her. Question, I am planning to add grip puppies. Would you happen to know the correct size I need? In addition the search I did on here talked about coating them with hairspray prior to install. What's the purpose of that? Thank you in advance!
Steve
Sent from my iPhone using MO Free
creedak is offline
post #2 of 6 Old 08-16-2012, 07:17 PM
1.25-1.45" diameter are the ones for the stock grips. They probably are 5" long and need to be shortened. The hair spray helps them slide on when wet and stick when dry.
post #3 of 6 Old 08-16-2012, 09:30 PM Thread Starter
Thank you very much Grey Wolf! Reading these forums I think you must be the "yoda" of Stroms!!
Steve
creedak is offline
post #4 of 6 Old 08-17-2012, 02:00 AM
mky
i put them on mine and the standard ones fit no need to shorten. I have now removed them as they did not suit me. Just use some water with a little soap and as you push them on run you finger around on the inside of the puppies helps them on
mky is offline
post #5 of 6 Old 08-17-2012, 08:21 AM
NovaStrom's Avatar
I have them on my Wee. The grips seemed so skinny compared to what I was used to and I like this feel a lot better. I had to trim a little off. The right one went on easily with hot soapy water but the left one wouldn't. I stuck it in a bowl of water and microwaved it and it slipped right on then. :mrgreen: Neither have budged since I got them on.
2012 Suzuki DL650 VStrom Adventure ABS
2008 Suzuki DR-Z125
2007 Triumph Rocket III Classic (R.I.P.)
2005 Harley-Davidson VRCSA
2000 Yamaha TTR 250
1999 Kawasaki Vulcan Drifter 1500
1998 Harley-Davidson Dyna FXDL
1993 Harley-Davidson Sportster XLH 883
1986 Husqvarna WR 400
1980 Honda GL 500
1974 Honda CB 200
1972 Honda CB 450
NovaStrom is offline
post #6 of 6 Old 08-18-2012, 08:18 AM Thread Starter
Awesome thanks guys! Curious Nova Strom where about you live? I just moved from NoVa. Spent the last 3 years at the five sided wind tunnel aka Pentagon. Lived in Kingstowne and now stationed at Dover AFB De.
creedak is offline
