heated grip + 12V connection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 08-12-2012, 08:17 PM Thread Starter
HI,
I bought the bike with heated grip and they are connected on the plug on the right side in the dash. I Recently bought the 12V oem plug. Where I can connect it? it has the same connection plug has the heated grip. Is there any other plug hidden on the bike?
thanks
Pascah is offline
post #2 of 6 Old 08-12-2012, 09:13 PM
The heated grip connector is behind the radiator. The connector on the right side is for an accessory plug.
post #3 of 6 Old 08-13-2012, 11:24 PM
Toytech's Avatar
Right! What GW said. The right side connector is for the OE power outlet. The factory heated grip connector is on/at the radiator, left side. It is held in place by a white tape wrapping. Both connectors are ign switch powered up.
From personal experience I can tell you to install the power outlet all the front fairing pieces will be removed. Tank side covers as well.
What brand are the grips?
I don't mind the going and I don't mind the stopping. I absolutely hate the stop and going.
Toytech is offline
post #4 of 6 Old 08-14-2012, 08:44 PM Thread Starter
thanks
the grip are from oxfort
Pascah is offline
post #5 of 6 Old 08-17-2012, 04:15 PM Thread Starter
Anyoene can help me locate the heated grip plug that greywolf talk about. Maybe with a picture pointing the plug. I can't find it
thanks
Pascah is offline
post #6 of 6 Old 08-18-2012, 11:03 PM
https://www.stromtrooper.com/dl650-20...install-8.html
Post #79 Compliments to Pnuematic
If you need a heated grip adaptor,
http://easternbeaver.com/Main/Bike_S...om/vstrom.html
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
Tags
glee , outlet
