Coolant Hose Replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 08-12-2012, 11:51 AM Thread Starter
I have a leak in the water pump inlet hose PN 17853-19F00 that needs to be replaced. From what I can make of this, there is no practical way of making the repair without lifting the fuel tank to replace coolant. Is there any way to avoid this as the tank lift is an exercise that I would like to be spared?
Thanks for any suggestions.
docbert is offline
post #2 of 12 Old 08-12-2012, 12:49 PM
That should be covered under warranty. Your Glee can't be out of warranty yet.
That being said, you can pinch off the overflow tank hose at the radiator under the cap before draining the coolant. Then you can drain the coolant without losing the portion in the under tank reservoir. Refill the radiator using a long funnel and that takes care of the coolant part of the problem. Access to the hose is another matter.
post #3 of 12 Old 08-12-2012, 02:41 PM Thread Starter
Thanks gw. The hose leak was unfortunately of my own doing. I have the replacement hose ordered and can now see how to address this fix. One final question--what should I do about a sealant when installing the new hose?
docbert is offline
post #4 of 12 Old 08-12-2012, 02:45 PM
xDownSetx's Avatar
No sealant, just make sure the inside of the hose and the barbs are clean.
'06 Silver DL1000
xDownSetx is offline
post #5 of 12 Old 08-12-2012, 03:10 PM
There's a story I'd like to hear.
post #6 of 12 Old 08-12-2012, 03:38 PM Thread Starter
I had hoped that nobody would ask. A very low speed drop in loose gravel exposed after lake water had dropped.
docbert is offline
post #7 of 12 Old 08-12-2012, 04:03 PM
Then the bike tipped over into the lake and the hose fell on Excalibur?
post #8 of 12 Old 08-12-2012, 05:05 PM Thread Starter
Not exactly--the bike actually fell away from the lake and there was no sword. The hose was pushed inward and tore under tension just forward of the pump housing connection. The resulting leak was very slight and very little fluid escaped before it was detected. Fortunately, there was no other damage to the machine.
docbert is offline
post #9 of 12 Old 08-12-2012, 05:32 PM
17853-19F00 is #6 in the figure 20. It is not where it can be damaged in a fall. Are you sure you aren't talking about the hose between the water pump and the heat exchanger, #6 in figure 17? It is 16471-44H00. Or is it the water pump to radiator hose, #3 in figure 20, 17854-44H00?
post #10 of 12 Old 08-12-2012, 05:46 PM Thread Starter
gw--It was Part #3 of Fig 20 (the one forward of the pump) which was pushed inward in the fall.
Last edited by docbert; 08-12-2012 at 05:52 PM. Reason: incorrect hose previously identified
docbert is offline
