2012 clutch adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 08-05-2012, 08:36 PM Thread Starter
Question 2012 clutch adjustment
Hi... anybody can tell me if the the clutch adjustment is done the same way as for the previous model.
15 000km and still no adjustment done. I love it.
Bernard101 is offline
post #2 of 8 Old 08-05-2012, 08:50 PM
It's totally different. The clutch pushrod free play adjuster is under the clutch cover. By the time the clutch friction material wears away to the point all the free play is gone, It may be a good idea to replace the friction plates because you'll be in there anyway.
post #3 of 8 Old 08-06-2012, 04:04 PM Thread Starter
Thanks a lot for the precision.
post #4 of 8 Old 10-02-2013, 09:51 PM
So just to be clear, on the 2012+ the only clutch adjustment available without opening the clutch cover is at the clutch lever. Is that correct?
Current Ride
2013 DL650
Past Rides
'08 C50
'81 CB900C
XR200
travism is offline
post #5 of 8 Old 10-02-2013, 10:34 PM
There is also an adjustment on the cable besides the one where the cable end meets the clutch lever perch.
post #6 of 8 Old 10-03-2013, 10:57 AM
Thanks. I was searching for the procedure to make that adjustment but could not find something specific to the Glee. I still have more play in the clutch pull than I would like and the handle adjuster is out of adjustment.
Current Ride
2013 DL650
Past Rides
'08 C50
'81 CB900C
XR200
travism is offline
post #7 of 8 Old 10-03-2013, 01:36 PM
oink's Avatar
Just a little ways down the cable from the handle adjuster.
oink is offline
post #8 of 8 Old 10-03-2013, 07:52 PM
Kenscoots's Avatar
And if that's not enough (to remove the slack), you can rotate the lever arm on the engine case and jump one spline (in the correct direction) to remove gross cable slack. It's already punch marked and scribed a starting point on the shaft. Just go back up to the lever adjustments to fine tune after.
Kenscoots is offline
