Bazzaz Update on the 2011-2012 V-Strom 650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-23-2012, 12:15 PM Thread Starter
Bazzaz Support's Avatar
Here is a good read on this amazing machine
http://www.bazzaz.net/Z-notes/PDF/Su..._650_11-12.pdf
Bazzaz
Tech & Sales Support
Rich McGee
909-597-8300 X 107
[email][email protected][/email]
Bazzaz Support is offline
post #2 of 7 Old 07-23-2012, 01:24 PM
D.T.'s Avatar
You only got 54 hp out of the stocker?? :shocked:
And only gained 4 hp out of the optimal map. And what? $300+ bucks?
Do you have the same sheet for the Suzuki Gladius?
D.T. is offline
post #3 of 7 Old 07-24-2012, 12:10 AM
Something is very, very, wrong w hp numbers indicated on the graph. I agree. Significantly down power numbers to everything I have read regarding the new motor. What's up with that!
phil323 is offline
post #4 of 7 Old 07-24-2012, 02:06 AM
pneumatic's Avatar
Your reading it wrong. Your reading the torque curve on the horsepower axis. It actually shows the stock bike is about 57HP and the modified fuel map gives 58HP (+1). The torque axis is magnified to make the torque increase look bigger.
As it is wheel horsepower it should be 10-15% less than the crank horsepower that manufacturers like to quote.
pneumatic is offline
post #5 of 7 Old 07-24-2012, 02:18 AM
pneumatic's Avatar
I found the gladius
http://www.bazzaz.net/Z-notes/PDF/Suzuki_Gladius.pdf
Looks like it went from 62.5 to 62.8 HP, but fixed some big holes in the torque curve.
post #6 of 7 Old 07-24-2012, 08:37 AM
D.T.'s Avatar
Yep, your right. Around 57 rwhp @ 8200 I assume for the stocker.
Boy, that gladius stocker, How in the hell does it run?? :shocked:
$379 bucks plus $$$ for tuning to get 2 hp?? Seems like Gladius cams and pistons are good for about 4-5 hp.
D.T. is offline
post #7 of 7 Old 07-24-2012, 10:24 AM Thread Starter
Thank you for clarifying this for us. Great catch
Bazzaz
Rich McGee
909-597-8300 X 107
