Sticking throttle - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-21-2012, 08:02 PM Thread Starter
Mo Throttle's Avatar
Sticking throttle
I installed Oxford hot grips on the Glee. Then tried to install my Vista cruise universal throttle lock. The wide flange on the grip put the lock too far from the anchor point, so I tried to place the lock between the switch housing and the grip, i.e., directly on the throttle tube. Fine. When I'm finishing up and tightened the bar end, the throttle was sticking open and not snapping closed. There was no clamping pressure on the throttle from the lock. I'd loosen the bar end and it would snap closed. Tighten it and it sticks. It's a snug fit between the switch housing and the grip end. It's almost if when I tighten the bar end, it draws up the grip and pinches the grip. So I removed the VC. When I tightened the bar end the throttle still sticks open!! The bar end and throttle were fine until the Oxfords were installed. What have I done wrong? P.S. I also have OEM handguards. Any ideas??
Thanks, Mo
"There's a race of men that don't fit in,
A race that can't stand still;
So they break the hearts of kith and kin,
And they roam the world at will."...Robert Service
Mo Throttle is offline
post #2 of 4 Old 07-21-2012, 08:56 PM
Check the end of the grip and throttle tube nearest the bar end weight. You may need to open up the hole in the end of the grip or move the throttle housing to the left a little.
post #3 of 4 Old 07-30-2012, 03:07 PM Thread Starter
I tried that. Nothing worked properly til I removed the vista cruise. AOK now. thanks Greywolf.
Thanks, Mo
post #4 of 4 Old 07-30-2012, 03:36 PM
When reinstalling my bar end I can cause the same problem with the throttle. It takes some adjustment to get it right and keep it free
