replacement battery - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 33 Old 07-20-2012, 11:37 AM Thread Starter
replacement battery
Just called my Suzuki dealer and found out that I have to bring my bike, with a dead battery, in to be checked out.
Too much hassle. What battery would you recommend for the new 650 V-Strom?
Mr. Pete----->
aging hippie
mrpete64 is offline
post #2 of 33 Old 07-20-2012, 12:00 PM
The easiest one for you to obtain with the best warranty.
A good but dead battery can be recharged. A defective battery on a new bike is possible but rare.
post #3 of 33 Old 07-20-2012, 12:54 PM
kenneth_moore's Avatar
If it were my bike under warranty, I'd like the dealer to check out the charging system, the wiring and fuses, etc. It's free and could save you a lot more hassle down the road.
Go hakafugu yourself.
kenneth_moore is offline
post #4 of 33 Old 07-20-2012, 03:05 PM
Purchased my wee, 2011 model in Feb, Wasn't to long after that, my battery left me pushing. The dealer did take a while, for they had to charge the battery, then test. THEN, when they called suzuki, the questions was like, what type of charger? did you use this type of charge mode? So, it took a few days more, for they had to order the special battery from suzuki, could not use any off the shelf. Now that it's over, works great. For me, I was not riding the the bike and I use my pickup to drop it off.
darmie is offline
post #5 of 33 Old 07-20-2012, 11:06 PM
VTOD's Avatar
I suggest Yuasa YTX12-BS. It can be shipped dry to your door from Amazon for $67. This assumes you are OK prepping a battery (easy) and you have a charger that will operate at 2A or less. It comes with instructions.
Sent from my iPhone using MO Free
'07 DR650
'14 Indy 800SP
'14 DL1000
VTOD is offline
post #6 of 33 Old 07-20-2012, 11:22 PM
tmcgee's Avatar
My experience: AGM Battery
tmcgee is offline
post #7 of 33 Old 07-20-2012, 11:59 PM
+1 on the AGM recommendation. I replaced the dead battery on my Yamaha Virago with an AGM a few months before I got my Wee, and it had ~20AH more than the original battery in about the same size. I didn't know that bike could start that quickly.
Be warned, though: "new" isn't the same as "working", so don't start looking for other problems just because you've put in a new one. The first battery I got from AutoZone wouldn't hold a charge, and it took me a couple of hours of scratching my head and doing all kinds of pointless tests to believe it.
Ben / 2012 DL-650A
Givi: AF3101 windshield, crash bars
Kuryakyn: 4141 GranTour Bag, 4171 Saddlebags, 4161 Cranker Tank Bag
RichlandRick: lowering kit, kickstand "shoe"
Stebel Nautilus horn/mount kit/wire harness
R&G swingarm spools
[URL="http://solarcapitalist.com/"]SAE power socket[/URL]
Handlebar GPS mount (RAM ball + Arkon case)
PerfectStrom is offline
post #8 of 33 Old 07-21-2012, 09:10 AM Thread Starter
thanks!!
Thanks for you insight(s).
Mr. Pete----->
aging hippie
mrpete64 is offline
post #9 of 33 Old 07-21-2012, 09:18 AM
Before doing anything else, tighten the battery cable connections. I had a dead bike a few days after buying it and tightening the connections, which weren't noticeably loose, fixed things completely.
post #10 of 33 Old 07-21-2012, 09:32 AM
Excellent advice, that (as greywolf's usually is.) I ran across it when I helped a friend fix a long-standing charging problem on his boat - he wasn't using that much juice for his house loads, but had to run his engine for 6 hours a day to keep up. One of the battery clamps wasn't noticeably loose - you couldn't turn it by hand - but had a 0.3V drop across it (the difference between a half-charged battery and a fully-charged one.) I tightened it, and he went from 6 hours down to 2.
I've got almost 40 years of playing and working with electricity, and hadn't realized that a big lead clamp on a big lead post, clamped tight enough that it couldn't be moved and visually clean, could make that poor of a connection. Score one more for the gremlins.
Ben / 2012 DL-650A
R&G swingarm spools
