ABS Switch - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 07-18-2012, 08:36 PM Thread Starter
ABS Switch
Has anyone added an ABS on/off switch.
loosesprocket is offline
post #2 of 19 Old 07-19-2012, 10:33 AM
Yes, I did, Eastern beaver sells all the bits to make one.
2012 Suzuki DL650AL2
Wilmo is offline
post #3 of 19 Old 07-19-2012, 08:30 PM
Sentinel's Avatar
Reports are that the new generation ABS system on the 2012 is so well designed and calibrated that it's really non-intrusive, even in the soft stuff; no off switch is needed...
Perhaps your experience is different?
Sentinel is offline
post #4 of 19 Old 06-18-2013, 05:57 PM
I wanted to bring this back to the top of the forum to see if there is any truth to this "rumor" that the ABS on the newer model V-Strom 650 2012+ don't need the ABS switch even in the soft stuff.
I just got mine June 5, 2013 and haven't had any chance to try it out and would prefer to hear some stories before I did! Thanks.
Beardsley is offline
post #5 of 19 Old 06-18-2013, 07:53 PM
chicago's Avatar
I can't imagine what they could do to an ABS braking system to make it trail friendly except for an on/off switch.
14 tooth for me
chicago is offline
post #6 of 19 Old 06-18-2013, 09:55 PM
njbill's Avatar
I can provide feedback on this. 30 minutes from my home is one million acres of state forest with hundreds of miles of sandy fire roads. I have logged countless miles in the sand over the past 35 years; mostly on single-cylinder dirt bikes without ABS. The Vstrom is my first ABS bike. Initially, I assumed I would have to install an ABS disabling switch. However, after several hundred miles in the sand, I no longer feel the need to disable the ABS. It is a very good system. YMMV
njbill is offline
post #7 of 19 Old 06-19-2013, 04:23 AM
Banned
I also have a similar experience to you. Nearly all my off road was previously done on a thumper. The DL650 is my first adventure motorcycle. I have now done quite a bit of fire trails and even a few steep hill passes and have had no issues with the ABS. The development of the latest system is amazing.
For what this bike is, it does OK off road, and I think that the ABS works to the bikes setup and intended use.
Who knows, as I start finding the need to get more and more adventurous an ABS off switch may be needed, but until now it seems to work well.
FoxOrange is offline
post #8 of 19 Old 06-19-2013, 12:30 PM
Thanks! I think I should be fine then without the switch then. I'm really planning on starting with very tame stuff nothing too hairy.
post #9 of 19 Old 06-19-2013, 12:49 PM
chicago's Avatar
Most riding off pavement, especially the way most ride stroms off pavement should cause little concern. An exception would be riding steep (emphasis on steep) downhills with a loose surface where you may find yourself astride a runaway train. There is a reason some 'adventure' machines have switchable abs. We just have the 'more affordable' version.
14 tooth for me
chicago is offline
post #10 of 19 Old 06-19-2013, 12:58 PM
Send a message via Yahoo to charliefrench2oo8 Send a message via Skype™ to charliefrench2oo8
I Installed a cutoff switch on mine, and have used it maybe 2 times? The only time you really need it is super steep loose dirt downhill, which in that case is hard to stop anyways. Here's an idea of what i'm talking about (Not a V-Strom in this video, but same idea)
BMW1200GS in free fall - YouTube - 32 Seconds in
Not enough hours in the day for riding
charliefrench2oo8 is offline
