Chain rubbing on swingarm - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By somniferous_sun
  • 1 Post By V-Tom
post #1 of 10 Old 07-17-2012, 06:32 PM Thread Starter
Hi everyone, this is my first post after lurking for a while and also after just purchasing a 2012 DL650. I love the bike (although this is the first time I've experienced buffeting). I do have a question about which I'm hoping you all can provide some advice.
I noticed that my chain is rubbing against the swingarm. Actually, it's rubbing against a protector that's on the top of the swingarm. Here is a fuzzy pic taken from the left side of the bike, looking from the rear sprocket towards the front sprocket. You can see that the chain is sitting on the protector.
I checked the chain tightness and it is within spec. Is this how it's supposed to work? I can't imagine that the chain should be rubbing on anything, ever. What am I missing?
macboat is offline
post #2 of 10 Old 07-17-2012, 06:35 PM
First time poster here as well. That's the norm on every modern Suzuki I've ever encountered.
Sent from my iPod touch using MO Free
team_milan is offline
post #3 of 10 Old 07-17-2012, 06:38 PM
tkwetzel's Avatar
That is normal. When the output shaft on the trans is spinning, it is generally pulling the top half of the chain tighter causing less rub, but that protector is there for that reason also.
2014 DL650AL4 - Too many farkles to list
2012 DL650AL2 (REBUILT)
tkwetzel is offline
post #4 of 10 Old 07-17-2012, 06:54 PM Thread Starter
Hey thanks for the input. I won't worry about it then. Kinda feel silly for asking now but I figured I wouldn't find out otherwise.
macboat is offline
post #5 of 10 Old 07-17-2012, 07:02 PM
V-Tom's Avatar
And welcome aboard!
..Tom
SMIDSY detailed report.
V-Tom is offline
post #6 of 10 Old 07-17-2012, 07:03 PM
V-Tom's Avatar
And welcome aboard as well!
If you haven't already check out the Canadian Section in Regional forums.
..Tom
V-Tom is offline
post #7 of 10 Old 07-17-2012, 09:30 PM
D.T.'s Avatar
Exclamation
Yep, that's OK. It's where I usually spray lube on the chain too.
Don't OVERTIGHTEN the chain to keep it off of that plastic. That's even worse than a loose chain in my opinion. Chain will be toast in no time, suspension won't work well and increase the load on the motor.
D.T. is offline
post #8 of 10 Old 08-08-2012, 09:54 AM
Yep!...and it will also ruin the oil seal on the countershaft as well as the O-ring behind it. Dont ask how I found out.
spidrgr is offline
post #9 of 10 Old 09-14-2017, 05:20 PM
Thanks
Hey! I'm new here. Just picked up a mint 2012 Wee two weeks ago. Was looking at the chain resting on the swingarm and was a little concerned, but after reading this thread, no longer!
Cheers from NZ.
V-Tom likes this.
somniferous_sun is offline
post #10 of 10 Old 09-14-2017, 08:02 PM
V-Tom's Avatar
Cheers from NZ.
Welcome aboard!
..Tom
somniferous_sun likes this.
V-Tom is offline
