Rectifier & Shock info on L2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 07-16-2012, 12:43 AM Thread Starter
I am thinking of possible upgrade to L2 and have a few questions:
1) is the rear shock on L2 just longer in length (if so, does anyone how much at the shock end), or does it have longer travel?
2) Does any know if the rectifier on L2 is a mosfet type?
thanks in advance,
cheers
aaron
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #2 of 10 Old 07-16-2012, 01:04 AM
The shock has more travel. The regulator acts like my MOFSET did on my Wee, but I can't say for sure.
post #3 of 10 Old 07-16-2012, 01:34 AM
xDownSetx's Avatar
If it's holding a stable voltage with very tight variance then it must be a fet, a diode shunt regulator isn't going to match a fet.
Maybe when someone has a free moment they can pull the bolts and google the painted part number on the bottom of the regulator.
'06 Silver DL1000
xDownSetx is offline
post #4 of 10 Old 07-16-2012, 02:00 AM
BrianTRice's Avatar
Well, the Suzuki part number is 32800-47H10, but that doesn't show much via Google.
BrianTRice is offline
post #5 of 10 Old 07-16-2012, 03:04 AM Thread Starter
pre L2 strom claimed 150mm travel for rear shock - what's the new one claimed to have?
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
post #6 of 10 Old 07-16-2012, 03:16 AM
BrianTRice's Avatar
The service manual lists 159mm for "Rear Wheel Travel".
post #7 of 10 Old 07-16-2012, 03:44 AM
I pulled mine off to add some heat sink paste. (Tip from a friend with a Honda). Didn't bother to note down the number.
Definately Shindengen, possibly FET. Like Greywolf, I suspect FET, it comes up to charging voltage at idle, the one on my K6 needed ~4000 rpm.
Pete
PeteW is offline
post #8 of 10 Old 07-16-2012, 04:03 AM
ozart's Avatar
My stock '07 goes above 14V at idle ... sometimes, and anything above idle iis always 14v+.
ozart is offline
post #9 of 10 Old 07-16-2012, 09:04 AM
D.T.'s Avatar
Pete
I did the same. Mine says SH811AA and 47H00 on the R/R. FET regulators look different and have 2 female connectors. Shunt R/R's have wires and a plug. Looks like there is a FET open style R/R. Never heard of that style. In the part # S is SCR style and F is FET style.
Here: http://www.shindengen.co.jp/product_...o/catalog.html
D.T. is offline
post #10 of 10 Old 07-16-2012, 07:13 PM Thread Starter
thanks for all the info -
L2 Glee;
K8 Wee ABS(SOLD);
AceRider is offline
