Help deciphering bolt size - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-13-2012, 03:28 PM Thread Starter
Snowkarver's Avatar
Hey guys,
The bolts/screws holding the fuel tank cover and headlight cowl in place (#13 and #14 in the fiche - the headlight cowling screw is the same as #13 I think).
OEM Parts
They are listed as "screw 5x13" and "bolt 6x8" respectively. Am I correct in assuming that the bolt #14 is a standard metric M6-1 that is 8mm long, and that the screw #13 is not a standard metric thread bolt size (hence it is a screw)?
2012 DL650 Shiro Nakama #27
Ride Report: https://www.stromtrooper.com/ride-reports-route-sheets/79121-footsteps-lewis-clark.html
Snowkarver is offline
post #2 of 8 Old 07-13-2012, 03:41 PM Thread Starter
Snowkarver's Avatar
Search is my friend, I guess. Looks like #13 is an M5x13mm buttonhead bolt.
post #3 of 8 Old 07-13-2012, 03:42 PM
Stromtrooper.com Sponsor
Satch's Avatar
Edit: Your edit made my reply meaningless.
Satch is offline
post #4 of 8 Old 07-13-2012, 03:47 PM
#14 is an M6x1.0 bolt, 8mm long in the shank. #13 is a shouldered screw as the shoulder takes it out of the definition of a bolt. It is an M5x0.8, 13mm long in the shank including the 3mm deep shoulder that is 8mm in diameter.
post #5 of 8 Old 07-13-2012, 03:54 PM Thread Starter
Snowkarver's Avatar
Thanks GW. Sorry about that Satch - I wrote a bunch of stuff that was itself rendered meaningless once I realized that I was reading the fiche backwards!
For context, I originally thought that the forward-most bolt was the M6, which would have given it the potential to mount RAM stuff from. But in reality the M6 is at the back of the fairing piece underneath the seat, and the usefully exposed one is the more unusual M5-13, which doesn't help me at all.
post #6 of 8 Old 07-13-2012, 04:42 PM
Oop North John is offline
post #7 of 8 Old 07-13-2012, 04:52 PM Thread Starter
Snowkarver's Avatar
Hey, thanks for the idea. Those Hawk mounts are a bit overkill for my intended usage, but its specs and assembly instructions are super useful. I think I might be able to fab something up. Thanks again.
post #8 of 8 Old 07-13-2012, 08:03 PM
There are four critically important specs for a threaded fastener.
...Diameter
...Length of the shank
...Pitch of the threads (millimeters per thread or threads per inch)
...Material..type of metal and the strength rating
