Warm Engine Start-up - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 07-10-2012, 02:07 PM Thread Starter
VTOD's Avatar
Anyone notice that when the engine is really warm it sometimes has a tough time turning over? We've had some hot weather up here in Wisconsin lately and I've noticed this a couple of times when starting her after a short stop. It brings back bad memories of my FJR which began doing this and it turned out to be a bad starter which likely toasted a relatively new battery also. That bike had much higher mileage.
The new Strom has just over 1000 miles and I do have a skid-plate attached which I'm guessing may hamper the ambient cooling in this region. I'm thinking I should at least stop by the dealer and have them load-check the battery and maybe check starter current draw at start up?
Thanks, advice appreciated!
'07 DR650
'14 Indy 800SP
'14 DL1000
VTOD is offline
post #2 of 17 Old 07-10-2012, 02:38 PM
D.T.'s Avatar
I'd say your battery is on it's way out. Unless you mis wired a farkle or it just uses current all the time.
Mine starts fine, even with a Shorai battery. Hot or cold.
D.T. is offline
post #3 of 17 Old 07-10-2012, 02:38 PM
Just open the throttle to let in more air whenever it doesn't start right away. The heat drives fuel fumes into the intakes.
post #4 of 17 Old 07-10-2012, 03:08 PM Thread Starter
VTOD's Avatar
Thanks guys - I have seen threads describing hard-starting when warm but I'm guessing that those bikes are turning over fine, just not firing. In this case it starts to turn over but so slow that it almost sounds like it seizes. I wait a few seconds, try again and it'll go. If it turns over it starts fine.
I'll start with the battery and hope that this is the problem. Hopefully warranty covers regardless of outcome. I'll post findings.
'07 DR650
'14 Indy 800SP
'14 DL1000
VTOD is offline
post #5 of 17 Old 07-10-2012, 03:42 PM
Might be worth checking that the starter and battery connections are clean and tight. Just DAMHIK :rolleyes1:
Oop North John is offline
post #6 of 17 Old 07-10-2012, 03:43 PM
Slow cranking is a different problem.
post #7 of 17 Old 07-10-2012, 04:09 PM Thread Starter
VTOD's Avatar
Good point Oop North,
I'll do what I can myself tonight:
1. Check connections
2. Test battery voltage while running
3. Test battery voltage at shut down
4. Test battery voltage in the AM before start-up
If nothing is discovered I'll have to hit the dealer's shop to load test the battery and/or check current draw from starter.
Thanks.
'07 DR650
'14 Indy 800SP
'14 DL1000
VTOD is offline
post #8 of 17 Old 07-10-2012, 08:55 PM
JayS's Avatar
i have had the opposite, when my bike is warmed up it cranks over really fast. like others mentioned check battery first...start easiest to hardest!
~~~>Jay<~~~
JayS is offline
post #9 of 17 Old 07-10-2012, 10:27 PM Thread Starter
VTOD's Avatar
Hey fellas,
The battery connections are good. I also checked the one connection on the starter that I could reach easily which is on the right side under a black rubber boot and this is good also.
Battery at around 3K RPM - 14.25VDC
Battery a couple hours after sitting - 12.80VDC
It SEEMS like the battery is OK. Since the bike is only a couple months old I'm tending to believe this but I do know that they can be tricky. It certainly starts cold as well as any bike I've had.
It's typical for me to try to stay ahead of these things but given this is a somewhat intermittent "issue" and the bike is under warranty for another 10 months I'm considering leaving it alone to see if it gets worse. It hasn't stranded me yet. Does this make sense or does anyone think I'm risking damage that I won't want to deal with? Another thought I had was calling my dealer to describe what's going on and get their take. If nothing else they'll have an early record of events but maybe they will want to take a look at it too.
Also a general thanks to everyone on this forum. I've learned a lot about this bike here before I even bought it - and had a lot of good chuckles too! I owned a Versys for the last four years but was lurking over here for a good portion of that time. The Versys was a great bike too and has a good supportive forum.
'07 DR650
'14 Indy 800SP
'14 DL1000
VTOD is offline
post #10 of 17 Old 07-10-2012, 10:40 PM
D.T.'s Avatar
I'd ride it to the stealer on a hot day and then show them what you mean, easy enough. See what they say. Probably "that's normal" is the standard answer.
Seem like the battery checked out OK.
D.T. is offline
