Replacement handlebars - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-08-2012, 07:17 AM Thread Starter
D.T.'s Avatar
Question Replacement handlebars
So which handlebars will work for the L2? I'd like to get some with not so much pull back. The stock height is OK, maybe even a bit lower. I was reading some other threads in the pre L2 forums and it seems like ATV handle bars seem to the the ones people use.
D.T. is online now
post #2 of 7 Old 07-09-2012, 06:00 PM Thread Starter
D.T.'s Avatar
I have a Moose CR Hi bend on my XT and I'm thinking of trying it on the L2. It comes in orange too! May use black instead. Carbon steel bars are around $24 bucks. I'll let you guys know how and when I get R dun.
I saw someone use a Protaper ATV mid bar? 7/8" I assume?
D.T. is online now
post #3 of 7 Old 05-04-2013, 12:02 AM
MNrider's Avatar
Any solutions?
Did you ever get new bars? I want about the same thing as you outlined. But I'm going to install a Scott's stabilizer also, so cross bar handlebars are limited or completely out of contention.
2012 650A
MNrider is offline
post #4 of 7 Old 05-04-2013, 02:11 AM
Nope, my pro-taper SE's fit just fine above a Scotts. Admitted the foam protector on the cross bar does push the back of the damper and I have my bars well tilted back, but even above the damper there'd be room if the foam was trimmed.
Oh, and the decent bars are worth the $$$, gets rid off the noodle feeling from the bars particularly when pushing hard.
Pete
PeteW is online now
post #5 of 7 Old 05-04-2013, 08:54 AM Thread Starter
D.T.'s Avatar
I did get the Moose bars. They were great if you want a more MX style Vstrom. Much better for a dirt bike.
But not better for my bum neck, so I put the stock handlebars back on.
D.T. is online now
post #6 of 7 Old 05-04-2013, 09:23 AM
todd900ss's Avatar
How 'bout some pics so members can get a idea of height and pull back.
Maker and model would be good also.
I don't like the flex in the stock bars. A little less pull back would be good also.
todd900ss is offline
post #7 of 7 Old 05-04-2013, 11:38 AM
i had the atv low bars on my '06 and swapped them over to my L2. i liked the straighter bars also. as you have prob read, they are a little lower than stock and the grips end up being a bit farther away, being straighter and lower. i moved over my barbacks(1 1/2" up and back). cables, hoses etc were a little tighter, but no binding at full lock. since i put on the galfer +2" ss front brake lines.
bobbar is offline
