Problem with Coocase - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 07-02-2012, 06:35 PM Thread Starter
I was having a problem with my Coocase. The alarm, lights, open-close feature would only work if I pushed down on the lid. I removed the case and popped out the connector assembly on the bottom of the case. I found that two of the three connectors were no longer soldered to their respective brass connectors--just barely touching the connectors. I soldered the wires back to the connectors, and now all functions have returned. I thought if you notice your Coocase lights, alarms, or other features not working, you might want to check the connectors on the bottom of the case.
Oldandslower is offline
post #2 of 9 Old 07-02-2012, 07:06 PM
CecilSaxon's Avatar
Now all I have to do is hook mine up and wait for it to stop working.
Clarksville, TN
Blue DL650K7~ sold
Orange DL650AL2
I like my brain. My brain likes helmets. I wear a helmet.
CecilSaxon is offline
post #3 of 9 Old 07-02-2012, 07:17 PM
BrianTRice's Avatar
Would you still buy the Coocase, knowing this now? (I don't have a problem with a little soldering, though.) I guess I'll remain in wait-and-see mode for a nice top case suitable for the ADV model, otherwise.
BrianTRice is offline
post #4 of 9 Old 07-02-2012, 09:53 PM Thread Starter
Yes, I really like the case. It works as advertised and is just the right size for me. I did a Google search for this problem and found other's had the same fix.
post #5 of 9 Old 07-03-2012, 08:49 AM
My experience with my new CooCase is the same. Twice I noticed the lock/unlock wouldn't work. I had to resolder the wires for that connection ( second time I thought I did a better job....) and on the trip to WV recently my son said the tailight in the case started blinking.....
When I got back all three wires were broken off at the copper slide connectors in the base. I cut the factory wires and added some wire to those to make it easier to work on. I carefully cleaned and soldered everything again. If it happens again I'll resolder it and pack it with silicone to keep it from moving around.
Definately not a "robust" design.....
realshelby is offline
post #6 of 9 Old 07-30-2012, 12:59 AM
JayS's Avatar
While on trip to Maine NH VT MA oh and Canada,..today all in 16 hours true story it was great, I notices my top case works when it wants too and now just won't do anything lights or alarm or lock unlock with remote. Glad u posted this I will check the box under top case or box inside top case under liner ? Thx.
~~~>Jay<~~~
JayS is offline
post #7 of 9 Old 07-30-2012, 02:49 PM
twistedthrottle's Avatar
If you should have this problem email us with a picture of the broken connector and a proof of purchase. Your name and address should be plenty if you purchased it directly from Twisted Throttle. We will happily send you out a replacement connector.
We also sell a Base plate wiring harness if you should need to replace that one as well.
Kevin
twistedthrottle is offline
post #8 of 9 Old 07-30-2012, 06:01 PM
Thanks for the information Kevin. Do you know if there has been an improvement in the design?
post #9 of 9 Old 07-31-2012, 11:42 AM
Not too sure at this point but If I hear anything I will be certain to post it here.
Kev
Tags
electrical connector , top case
