speedometer stays at ZERO "0" - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-02-2012, 01:53 PM Thread Starter
I was riding today and all of a sudden the digital speedometer started bouncing speeds up and down. Then remained at zero and hasn't budged since. Tried starting and restarting the bike to no avail ? Any idea what might of happened or what can fix it ?
Mtl-strom is offline
post #2 of 7 Old 07-02-2012, 01:56 PM
A wiring connection could have come loose or something could have happened in the panel or at the sender near the front sprocket.
post #3 of 7 Old 07-02-2012, 02:14 PM
stromdon's Avatar
Under warranty
I would'nt even mess with it,take it to your dealer,it's still under warranty...
stromdon is offline
post #4 of 7 Old 07-02-2012, 04:02 PM Thread Starter
Tried again and still a permanent zero for speed. I'm not wiring savvy or confident enough to play around with this so the dealer it will be. Greywolf"s explanation does make sense though. Everything works except for the speed and odometer related stuff. Gear indicator, time and other electronics work. Just hope this wont cost $$$. Nothing major happened to provoke this.
post #5 of 7 Old 07-02-2012, 04:29 PM
The bike is under warranty. It shouldn't cost anything.
post #6 of 7 Old 07-02-2012, 04:41 PM
BB63's Avatar
Assuming it is the same or similar to the SV, it will be the ceremac speedo drive in the front hub has smashed, usually from a sloppy job on refitting the front wheel after a new tyre or such.
Cheers brian
BB63 is offline
post #7 of 7 Old 07-02-2012, 04:48 PM
The Glee speedo sensor is not on the front wheel. It's on the front sprocket shaft like the Vee.
