Motorcycle Consumer News gaff? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 06-23-2012, 01:07 PM Thread Starter
Just got my July issue of MCN. Noticed in Downtime files, a letter from a guy who had an 04 DL650 which burned regular gas. He was disappointed that the MCN article reported the new 650 needed premium fuel. What followed was a lengthy discussion about the adverse effects of long term detonation on a motor.
Well, I've been burn 87 octane in my 2012 Wee since new, however, I thought I'd better go check the owners manual. Sure enough, it says 87 octane. Email sent to MCN. I'm sure they will get many corrections. BTW, as I recall, they also stated the wet weight as over 900 pounds.
MCN is great magazine, just do your own homework.
racer is offline
post #2 of 19 Old 06-23-2012, 02:00 PM
Yes,
I saw that too....
Thought they were probably wrong re: the fuel.
That lil' 650 will run on pee.
Also, the wet weight and GVW were obviously reversed.
They list
Wet Weight / 915
GVR / 516.5
I still subscribe and like the mag.
I called the editor once, Dave Searle,... got right through. Nice guy.
Everybody makes mistakes... everybody's feeling the pinch of our "recoved economy".
Dmilan
Dmilan is offline
post #3 of 19 Old 06-23-2012, 02:15 PM
That's what happens when you don't have sponsors to keep you honest!:mrgreen:
post #4 of 19 Old 06-23-2012, 04:50 PM
chicago's Avatar
I noticed that too and was disappointed. So the manual does specify regular stuff after all. Good.
14 tooth for me
chicago is offline
post #5 of 19 Old 06-24-2012, 12:04 AM
Regular here is 85.5 so I have to use at least midgrade if I want 87 or higher.
2012 DL650 ABS Adventure
2016 Beta XTrainer 300
2008 WR250R
2005 R1200GS
1988 K100S
1975 XS650
kenfm2000 is offline
post #6 of 19 Old 06-24-2012, 08:18 AM
Sov
Sov's Avatar
It's a small world. I read the same MCN Downtime Files section yesterday and promptly got my Owner's Manual out to double-check - sure enough, 87 required minimum. I'm surprised that they didn't catch it by doing a little research before responding to the question. Or maybe premium means different things to different folks? I also sent a friendly FYI e-mail to the editor about it.
(12) DL650 (09) DR650 (09) FZ6
Sov is offline
post #7 of 19 Old 06-24-2012, 09:23 AM
The 87 or higher is for typical elevations. In higher elevations where 85 is sold, it works fine.
post #8 of 19 Old 06-24-2012, 10:50 AM
<<The 87 or higher is for typical elevations. In higher elevations where 85 is sold, it works fine.>>
Pat, that had always been my understanding until a few years ago when I bought a vehicle with a Ford Triton V-10 engine. In the engine owners manual it states that the recommended octane is 87, and then states that Ford does not believe in using a fuel with less than 87 octane at higher elevations. It's very specific about this.
Of course our V-stroms do not have Ford engines and my DL 650 owners manual isn't specific about this one way or another, simply stating "Your motorcycle required regular unleaded gasoline with a minimum pump octane rating of 87 ((R+M/2) method)." It does say regular but doesn't mention other than 87 octane, at least that I could find, so I find this quite confusing.
This is of particular importance to me because my home is at 5700 ft elevation and the town where I buy most of my gas is at 5280 ft (calls itself "the mile high town") and regular is 85 octane, mid-grade 87. Wanting to err on the side of caution, I've been explicitly following the Suzuki manual and using 87 but wondering if I'm wasting my money, which, being retired, I would rather not do.
Have you, or anyone else, perhaps discussed this issue with Suzuki for clarification?
Thanks for any further clarifying input. I need it! )
Mike
Idaho
www.rtwrider.net
liketoride2 is offline
post #9 of 19 Old 06-24-2012, 10:59 AM
If an engine doesn't ping, there is enough octane. I use 85 on trips in the mountains and it works fine.
post #10 of 19 Old 06-24-2012, 11:24 AM
Do Suzuki uses knock sensors? I know the BM F800GS / F650GS twin do, and get really economical fuel consumption figures, which when reading tests the L2 gets close to but is still about 10% worse than the BM.
Oop North John is offline
