Alignment of brake and clutch levers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 06-22-2012, 10:37 PM Thread Starter
chrisbre's Avatar
Hi folks, I moved my brake and clutch levers to suit being able to shade the levers easily in traffic. The manual mentions the need to align both levers with some dot (that I haven't found) on the handlebars. Is this important -- or can I just move the levers as I please? thanks
chrisbre is offline
post #2 of 5 Old 06-22-2012, 10:50 PM
As long as they work, you're fine. Just make sure everything works properly. Don't let the clutch lever hit the flash to pass switch for example.
post #3 of 5 Old 06-22-2012, 11:05 PM Thread Starter
chrisbre's Avatar
Talking right
Thanks for that GreyWolf -- Yes -- at one point I couldn't work out why the trip meter readout was changing all the time -- the clutch lever was hitting the meter select switch.
chrisbre is offline
post #4 of 5 Old 06-22-2012, 11:07 PM
Oops! I forgot what forum this was in.
post #5 of 5 Old 06-24-2012, 03:20 PM
I had the same problem with the clutch lever hitting the Select switch and initially thought the problem was a faulty instrument.
docbert is offline
