New Led lights and brackets - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-22-2012, 11:58 AM Thread Starter
I have just fitted a set of LED driving lights to some SW-motech brackets. The brackets are great and easy to fit. I have fitted a spot beam and euro beam LED light. I bought these direct from the manufacturer in China and am very happy with the look and quality. As far as light goes they are brighter than the standard high beams and are white light much like a set of HID lights.
foxstrom is offline
post #2 of 3 Old 06-22-2012, 06:35 PM
The Golden Monkey's Avatar
Looks good. More info on manufacturer, model, specs? Also it would be great to see separate beam photos of each.
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #3 of 3 Old 06-23-2012, 02:48 AM Thread Starter
I tried taking some photos but they did not turn out to good. I will try again when I get a chance. The euro beam is a cross between a flood and a spot. Actual light projection would be less than the standard lights but road reflectors are illuminated further away. They are great on country roads and give a large flood of light in the space left vacant by the standard high beams. You could not use these lights with oncoming traffic though as they are to bright.
foxstrom is offline
