2012 wee adventure 80mph cruisin ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 06-17-2012, 06:40 AM Thread Starter
i like cruisin at 80mph but for now i find my new wee a little tight and buzzy around 6000rpms. wil it get smoother as the miles add up and the breakin is completed. thanks
livharder is offline
post #2 of 12 Old 06-17-2012, 08:40 AM
D.T.'s Avatar
I doubt it. May get worse actually. I put some rubber washers between the frame and footpeg mounts. It helped a little bit. Smaller displacement compared to the 1000 makes it a bit buzzier.
D.T. is offline
post #3 of 12 Old 06-17-2012, 08:47 AM
I have about 2k on my '12 NewStrom and it buzzez a bit at 4500 rpm. Smooth above and below. In top gear it's about 65 mph. Don't have to look at the speedo. Also reminds me when to shift !
Mitch
Hollyweird, Fla.
mitch96 is offline
post #4 of 12 Old 06-17-2012, 09:04 AM
garandman's Avatar
I log all fuel use. On my 09 mpg improved steadily for the first 7,000 miles, so that's what I consider the break in.
Try taking your bags off - they are quite wide on that model and reducing the drag and corresponding smaller throttle setting may help.
garandman is offline
post #5 of 12 Old 06-17-2012, 10:29 AM
The buzzing is caused by the engine guards. Putting a rubber shim between the joint on the bars in front of the engine is the usual fix.
post #6 of 12 Old 06-17-2012, 10:43 AM
What greywolf said. Read more about it here,
https://www.stromtrooper.com/dl650-20...ibrations.html
Mine was butter-smooth everywhere, then I installed the OEM crashbars, and I got vibes in the handlebars at 4500-4900, and again around 6000, but more so in the footpegs at 6K. Putting some rubber between the attach points in the middle helped quite a bit, and according to others soon as I get me a third mounting point (new skid plate) to attach to the bars it will be gone. If not I need a skid plate anyway.
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #7 of 12 Old 06-18-2012, 12:55 AM
mjbiren's Avatar
I gotta say I don't have any crash bars and I don't personally find the ride buzzy all the way up to 7k.
But your experience will be different than mine. For instance - I come from a Ninja 250. 9K RPMs at 80. That's buzzy!
mjbiren is offline
post #8 of 12 Old 06-18-2012, 11:24 AM
Hey guys and gals...........it's a motorcycle.........
racer is offline
post #9 of 12 Old 06-18-2012, 11:59 AM
Living the Stereotype
Stromin'Nroman's Avatar
I thought it was a lifestyle?
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #10 of 12 Old 06-18-2012, 12:08 PM
Engine will smooth out, make sure your chain is properly adjusted, make sure everything is good and tight.
