Alternator output on 2012+ - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 06-15-2012, 07:27 PM Thread Starter
I just put a 12V power socket on my Glee, and I plugged in my portable voltmeter that I use to monitor my voltage in the winter with my heated gear, and went for a ride. I noticed the voltage output was 13.8V-13.9V at 4K-5K rpm's with no extra loads. On my K7 same voltmeter would read about 14.5V again with no load. The K7 would have a lower voltage at idle, where as the L2 doesn't vary as much between idle and say 5K rpm. I have no idea about actual output watts available, as I am not about to put my heated gear on in this weather. The L2 should have 25 extra watts available over a K7. I guess my question is what should normal running voltage be with no load?
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #2 of 8 Old 06-15-2012, 07:52 PM
Based on the way the voltmeter parallels the MOSFET equipped 2007 I used to have, I'd say the regulator is just doing a better job. Higher voltage doesn't mean more power is available, it means the regulator is allowing a higher voltage level before shunting off the excess.
With a fully charged battery, I am seeing ~13.8V in normal use. Once I was doing some work involving turning the ignition and lights on for a bit without the motor running. For a while after that, I was seeing up to 14.3V as the system was putting more power out to charge the battery. My '07 was doing exactly the same thing with a MOSFET regulator.
post #3 of 8 Old 06-16-2012, 06:28 AM
IF the 2012 has a MOSFET regulator there's about 14W more available due to the improved electrical efficiency. Possible more effectively at lower rpm's.
Pete
PeteW is online now
post #4 of 8 Old 06-16-2012, 02:20 PM Thread Starter
Just went for another ride and noticed at idle, it was about 13.5-13.6V, and again 13.8V-13.9V at higher RPM's, pretty steady, doesn't vary a lot between idle and 5K+ RPM's. The old Wee (K7) would be 12+V at idle, can't remember exactly but it was 12.xx something. So the Glee is definitely better at low rpm and more consistent overall, but not as high of a peak voltage. I know this means nothing far as power output, just my observations.
Kevin
khager is offline
post #5 of 8 Old 06-16-2012, 02:46 PM
It also takes a short period of time to ramp up voltage after starting. It acts just like the MOSFET R/R I put in the old Wee.
post #6 of 8 Old 06-16-2012, 03:45 PM Thread Starter
Yes you are right Greywolf, I noticed that too, just failed to mention it.
Kevin
khager is offline
post #7 of 8 Old 09-08-2013, 08:06 PM
I realize this is an old post, but my battery monitor on my 2013 Wee shows that it charges in the area of 14.5 at a couple of thousand rpm. At idle it is in the 13's. This is with a resting voltage of 12.7 on the battery.
cycleman is offline
post #8 of 8 Old 09-11-2013, 08:47 AM
Captain Farkle's Avatar
Same, purchased a chinese voltmeter and run it all time for the same reason as the June poster heated gear. I can run Gerbings jacket and gloves with heated Oxford Grips and charge my cell at the same time. Hits about 12.3-12.5 at idle and 13. somthing at 3-4K.
I live in Canada so already had the heated gear on last weeks morining commutes. I do shut off the grips once I hit a city with a lot of traffic lights and the gear is not turned up too much yet about 1/3 of the way on the gloves and just on for the jacket.
2012 650 Vstrom Black - Givi E52 Maxia Trunk,Givi Quick Release PLR3101 Racks, Givi E21 Silver Side Cases, Admore LED Brake and turn signals, SW Motech Crash Guards, SW Motech Center Stand, SW Motech Steel Rear Rack, SW Motech Bar Risers, OEM lower Cowling, OEM lower Seat customized by Triple K Upolstery, OEM Hand Guards, Eastern Beaver PC8, Givi Airflow Windscreen, Aprilla Mirrors, Dan Vesel Highway Pegs and Back Rest, Oxford Sport Heated Grips, FendaExtenda, Sena 10C, CREE LED Headlight Kit,10w Cree LED Work Lights,INNOV Wifi Bullet Cam
Captain Farkle is offline
