Would aligning the headlights be a warranty service?... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 37 Old 06-15-2012, 01:13 AM Thread Starter
glasswave's Avatar
My head lights when on bright seem to points up at the trees on the left side of the road. Oddly enough, the low beams seem pretty good. They definitely seem better than the brights.
Do you think it's reasonable to ask a dealer to align them on warranty? I bought my bike w/36miles used from a dealer 400 miles away, so it's not like I am returning to the dealer where I bought my bike for the service.
[SIZE="1"]Trips:
Indian Himalaya:Gangotri-Shimla-Manali-Pavarti-Spiti-Leh-Kargil-Padum-Sringhar-Daramsala (3 mo.--2x)
Kazakstan-Krygyzstan-Tajikistan-Xin Xiang to Lhasa, Tibet on China 219!-Nepal (7 months)
Santiago, Chile to Ushuia Argentina and up to Cusco, Peru (7 months)
Peruvian Andes (3 months)
N Chile - Medellin, Colombia (3 months)
Cartegena, CO to N Chile (3 months)[/SIZE]
glasswave is offline
post #2 of 37 Old 06-15-2012, 05:30 AM
Glad to hear I'm not the only one with this problem. My high beams seem to point to outer space. The low beams also seem diffuse and unfocused. When I brought the bike to the dealer for my ($250!) 600 mile oil change, I asked them to adjust the headlights. Instead, they gave me a copy of the service manual page showing how to adjust the headlights, and said to do it myself. I'm thinking of writing to Suzuki about it. Meanwhile, I avoid night riding. Seems like I deserve more than this for the $9100 out-the-door I paid.
mstamper is offline
post #3 of 37 Old 06-15-2012, 08:00 AM
D.T.'s Avatar
Angry
Same here. And the blue high beam light is pretty glaring also!
Seems like customer service is a thing of the past, if it ever was there that is. I brought my truck in for a front end alignment and nearly $400 later it's marginally better.
I may try and adjust the high beams myself here though.
D.T. is offline
post #4 of 37 Old 06-15-2012, 08:06 AM
I also have that problem, I'm going to adjust it myself. I fixed the bright high beam indicator by cutting a round piece of electrical tape and putting it over the light, now all I get is a nice glow around the tape. I think if someone came up with the correct fitting bulb at about 1/4 the brightness it would be great.
P.S. If this is the only problem I have out of this bike it will be great.
glastron is offline
post #5 of 37 Old 06-15-2012, 08:22 AM
It's a surface mounted LED, not a bulb. Replacement would be very difficult and it may not be possible to do it with less light.
post #6 of 37 Old 06-15-2012, 08:42 AM
So what does replacement entail when one burns out? Do you have to replace the whole dash? Just a curious question.
glastron is offline
post #7 of 37 Old 06-15-2012, 08:55 AM
LEDs don't burn out. Isolated, small signal LEDs typically last hundreds of thousands of hours before light output falls to 50% of original output.
post #8 of 37 Old 06-15-2012, 10:25 AM
Look at the base of the bulb through the headlight lens. It sounds like the bulb (or both) are not correctly seated in the light housing. You can see this from the front more easily than from the back. The bulb needs to be in the orientation shown in this picture with the center contact on top, and the three wings of the base seated in their slots. Resetting the bulb in its housing is easy. When I pull off the rubber boot, I put a dab of silicone lube on the area of the boot that fits over the housing...it is easier on and off the next time.
post #9 of 37 Old 06-15-2012, 11:24 AM
V-Tom's Avatar
For what it's worth It really is a fairly easy job to adjust the headlights and doing so can make the lights feel many times brighter.
Put the bike on the centerstand and point it to a wall, or a sheet of cardboard that has some horizontal lines in it. Mask one headlight while you adjust the other and then repeat on the other side making sure they are at the same level. Go for a little ride and see the results then adjust them both the same amount and try again. It is amazing how much difference a pair of properly adjusted headlights can make!
..Tom
SMIDSY detailed report.
V-Tom is offline
post #10 of 37 Old 06-15-2012, 11:27 AM
V-Tom's Avatar
I found the blue high beam indicator to be a major annoyance when I got my NewStrom. (My eyes are very senstitive to glare.) I considered putting a bit of tape to block most of the blue light but never did. Now with over 15,000 km I find I don't notice it anymore.
..Tom
V-Tom is offline
