Universal rear rack? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 06-14-2012, 02:34 PM Thread Starter
Rydah's Avatar
Anyone know of a good universal rear rack that will fit? Found this one, and it looks nice, though a bit pricey:
Rear Luggage Rack, Suzuki V-Strom DL650, 2012-on - Touratech-USA
Anyone have something different?
"The Night Rydah.. remember him, when you look at the night sky" - Toecutter
Rob
2006 XR650R - Plated[B][/B]
2012 650 Vstom
Rydah is offline
post #2 of 17 Old 06-17-2012, 04:25 PM Thread Starter
Rydah's Avatar
Wow, noone has a rear rack? Are they that scarce? Guess I may try to fabricate one myself from some aluminum plate then.
Rob
2012 650 Vstom
Rydah is offline
post #3 of 17 Old 06-17-2012, 04:40 PM
The H & B rack can be used like the TT one, or use the adapter to attach one of their top boxes onto. Looks ok in either mode, but not very wide / deep.
Oop North John is offline
post #4 of 17 Old 06-17-2012, 04:42 PM
Most people either use the stock rack or add a mount specific to a hard topcase.
post #5 of 17 Old 06-17-2012, 05:06 PM
SW Motech Rear Rack
I went with the SW Motech Rack as they sell the kit to fit with the Trax Top Box, it's made of laser cut steel and was $119.00. Fits well and is nicely finished.
If you are not going with a top box why not just stick with the factory one?
Kiwi Canuck is offline
post #6 of 17 Old 06-17-2012, 05:19 PM Thread Starter
Rydah's Avatar
I've got a Pelican case that I'd like to mount back there, but would also like the ability to strap more stuff on if needed. The stock one seems like it would get scratched up too easily, plus it doesn't really have good connection points for straps. I might just fab up a basic rectangular aluminum plate with some oval holes around the edges for strap connections, and use the mounting bolt holes that are already there to connect it and the Pelican.
I'll look at the H&B one as well, but the prices sure seem high for just a piece of metal. Thanks for all the replies fellers.
Rob
2012 650 Vstom
Rydah is offline
post #7 of 17 Old 06-17-2012, 07:55 PM
glasswave's Avatar
Ya might be looking for something like this. It's a fair bit larger than the Touratech and has better tie down points, IMHO. It's a strong & lightweight Aircraft Aluminum cargo plate that measures 15.5" wide x 13" long w/lots of tie-down slots machined into the perimeter. It's still a tad pricey at $90, but it is also designed to mount your Pelican. The hardware for a locking quick mount system for a pelican box is sold separately. It's also set up specifically for the 2012 wee!
I am using Roger's side case system and am very impressed with the quality and how well thought out the system is.
Caribou Cargo Plate
[SIZE="1"]Trips:
Indian Himalaya:Gangotri-Shimla-Manali-Pavarti-Spiti-Leh-Kargil-Padum-Sringhar-Daramsala (3 mo.--2x)
Kazakstan-Krygyzstan-Tajikistan-Xin Xiang to Lhasa, Tibet on China 219!-Nepal (7 months)
Santiago, Chile to Ushuia Argentina and up to Cusco, Peru (7 months)
Peruvian Andes (3 months)
N Chile - Medellin, Colombia (3 months)
Cartegena, CO to N Chile (3 months)[/SIZE]
glasswave is offline
post #8 of 17 Old 06-18-2012, 06:36 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
There is this:
Adventure MotoStuff V-Strom Luggage Rack V2.0 - Black
But I prefer this version with the Givi Adapter:
Adventure MotoStuff V-Strom Adjustable Topcase Mounting System V3.0 For Givi Monokey Cases
Also works with the JC Whitney Top Case.
Just remove the adapter for a flat surface and put back when you want the top case again.
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #9 of 17 Old 06-18-2012, 07:16 AM Thread Starter
Rydah's Avatar
Originally Posted by vegashotwheeler View Post
Thanks, Mike. That shows to fit the DL1000 though; will it also fit the 2012 DL650?
Rob
2012 650 Vstom
Rydah is offline
post #10 of 17 Old 06-18-2012, 07:20 AM Thread Starter
Rydah's Avatar
Originally Posted by glasswave View Post
... but it is also designed to mount your Pelican. The hardware for a locking quick mount system for a pelican box is sold separately. It's also set up specifically for the 2012 wee!
Caribou Cargo Plate
Ouch! $90 for a piece of aluminum. Tell me about this locking quick mount for a Pelican you speak of, and who is Roger?
Rob
2012 650 Vstom
Rydah is offline
