So I'm an idiot - point out where the drain plug is for me?! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 06-07-2012, 06:08 PM Thread Starter
At about the 3,000 mile mark I decided to change the oil on my bike, despite having had the 600 mile service done just at the end of February, because I ride so much in the city that it's really well over 300 hours of riding with a lot of low gear constant shifting. Since the manual indicates I only need to change the filter with every other oil change I figure I'm good for just draining and refilling the oil.
I've changed the oil on my other bikes but I can't find the drain plug on the 2012 DL650. The manual points at a bolt that I can't map easily. I found a bolt on the underside of the engine that I thought was the drain plug, it has a "4" on it, but I removed it practically all the way out without any oil coming out, so I don't think that's what it is.
I have the OEM under cowling attached so it might be obscuring where the drain plug is, but when I looked under the cowling all the bolts I can see seem to be attaching the exhaust to the engine.
Er... A little help?
robardin is offline
post #2 of 9 Old 06-07-2012, 06:18 PM
It's number 1. It's an older pic but it's at the same position and the cast fin in front ot it is a dead giveaway.
post #3 of 9 Old 06-07-2012, 06:19 PM
pneumatic's Avatar
This is it on the old one, it looks pretty similar
pneumatic is offline
post #4 of 9 Old 06-07-2012, 06:20 PM
fortp's Avatar
Just curious, why did you not removed it completly?
That was the good one...
fortp is offline
post #5 of 9 Old 06-07-2012, 06:33 PM
Oil pretty much stays in place until the plug is totally withdrawn.
post #6 of 9 Old 06-07-2012, 06:46 PM Thread Starter
I see... On my Kawasaki VN750 it starts spurting oil about halfway from fully removing the plug, which has much less thread on it too. I had the feeling I was removing an engine mounting bolt :P
So I probably had it right then!
Sent from my Motorcycle iPhone app
robardin is offline
post #7 of 9 Old 06-07-2012, 07:07 PM
The fin is the clue. There are oil gallery plugs at the bottom too but no mounting bolts.
post #8 of 9 Old 06-07-2012, 10:24 PM
EVstrom's Avatar
I'm glad Grey Wolf beat me to the reply - I thought you were talking about this drain plug:
Master of the obvious...
Ol' Bug Brain of the Sons of Practicality MC
2012 DL650AL2
EVstrom is offline
post #9 of 9 Old 06-08-2012, 12:10 AM
And just to make sure you have the correct bolt, it is on the left side of the bike. Behind the little fin, as mentioned above.
_____________________
Regards, MillCreek
Snohomish County, Washington USA
2012 Suzuki DL650A
Three road, two mountain and one folding bicycle
MillCreek is offline
