Radiator hose rubs on the GIVI crash bar - an easy fix! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-04-2012, 04:32 PM Thread Starter
Don_T's Avatar
Lightbulb Radiator hose rubs on the GIVI crash bar - an easy fix!
When I installed the GIVI crash bars on my 12 V-Strom, I noticed that it touched the Radiator hose on the right hand side of the bike - but only just.
After 5.000km I could see that the crash bar had left a small mark on the hose.
I don't think that it will cause any problems, but just in case I've done a small modification to solve the "problem".
The rub mark on the radiator hose:
To prevent the hose rubbing on the crash bar, I shortend the hose about 5mm where it connect to the engine:
I did it with the hose in place - using a Stanley blade to cut away the piece of hose that was on the inside of the clamp (being careful not to scratch the stud with the blade).
Then I loosened the clamp, pushed the hose all the way in and retightende the clamp.
The whole process took about 5 minuts and the hose didn't leak one drop of coolant.
Now there is a sufficient amount of clearence between the crash bar and the hose:
An easy fix to a small but potential problem.
Yamaha XT1200Z '15 - www.bike-addict.dk - It's not what you ride but how you ride it unk:
Don_T is offline
post #2 of 3 Old 06-04-2012, 07:58 PM
okidave's Avatar
Smile
Thanks for the info. I was the one who PM'd you about this.
okidave is offline
post #3 of 3 Old 06-05-2012, 05:09 AM Thread Starter
Don_T's Avatar
Your PM was the reason that I posted the fix - maybe there are others who will find it usefull.
Don_T is offline
