Oil showing too high after all day ride - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-26-2012, 09:04 PM Thread Starter
I changed the oil this morning and I filled it to exactly the top line on the site glass using the center stand. Now after a 240mile run it's showing quite a bit higher and filling the whole site glass. Is this normal?
Sent from my Motorcycle iPhone app
timspong is offline
post #2 of 12 Old 05-26-2012, 09:13 PM
ozart's Avatar
You over filled it.
ozart is offline
post #3 of 12 Old 05-26-2012, 09:18 PM
Oil doesn't appear from nowhere. Using the center stand will make the proper amount appear too high. For the best measurement, both tires should be on level ground with the bike held vertically. I like the center stand myself but I know the level should be at the top of the glass in that configuration.
post #4 of 12 Old 05-26-2012, 10:31 PM Thread Starter
Both times I used the center stand though. All I can think of is that the oil somehow expanded after an all day run in 90 deg weather. I'll check again once it's cool to see if it goes back down to the fill line.
timspong is offline
post #5 of 12 Old 05-27-2012, 03:14 AM
tiller4me's Avatar
This motor originated in the TL models, and it is well documented that prolonged idling when cold will cause gas to wash past the rings and into the oil sump. I haven't heard of this issue with the SVs or VStroms, but it stands to reason it could happen. Pop your oil fill cap and see if you detect any fuel vapors.
79 GS1000S
97 TL1000S
2005 DRZ400
2005 KDX220R
2007 DLK
2009 KLR650
2007 FJR1300
2007 Honda XR650L
tiller4me is offline
post #6 of 12 Old 05-27-2012, 07:33 AM
After the OP's 240 miles ride, I'd think that any fuel would have evaporated off.
Oop North John is offline
post #7 of 12 Old 05-27-2012, 08:20 AM Thread Starter
Well I let it cool and the oil level went back down to the max line, Anyhow I have now drained a bit off to be on the safe side.
timspong is offline
post #8 of 12 Old 05-27-2012, 03:34 PM
How much did you put in it?
glastron is offline
post #9 of 12 Old 05-27-2012, 07:05 PM
If you aren't carefully monitoring the exact amount you are putting in but want to be fairly precise you could start the engine when you are near proper capacity...in order to fill the oil filter...then shut down...wait 10 minutes and complete your fill to the upper line.
xplorguy is offline
post #10 of 12 Old 05-27-2012, 08:52 PM
stoked steve's Avatar
I found it was pretty easy to overfill when I did my 600 mile service. I ended up needing to let a bit back out.
I did indeed start it up and let it cycle for a few and then let it settle back down before the final fill.
I found just about 2 3/4 quarts filled it properly, with filter change. 3 would be too much. The local dealer (not my purchase dealer) said I needed 3+ quarts, so I bought four, didn't need the 4th...I'll have it for next time.
'12 DL650A VStrom
stoked steve is offline
