Fit strom inToy Tacoma extended cab bed??... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-24-2012, 01:44 PM Thread Starter
glasswave's Avatar
Hopefully I'll be buying a Strom in the next week or so. I'll have to travel to get it. How well does it fit in a Toyota Tacoma PU bed. I believe that my bed is 72" and the vStrom is 90".
Does it fit OK with the tail gate down? If you angle it can you close the tail gate? I'd hate to drive several hundred miles and find out that I can't make it fit. Any advice would be helpful.
thx
[SIZE="1"]Trips:
Indian Himalaya:Gangotri-Shimla-Manali-Pavarti-Spiti-Leh-Kargil-Padum-Sringhar-Daramsala (3 mo.--2x)
Kazakstan-Krygyzstan-Tajikistan-Xin Xiang to Lhasa, Tibet on China 219!-Nepal (7 months)
Santiago, Chile to Ushuia Argentina and up to Cusco, Peru (7 months)
Peruvian Andes (3 months)
N Chile - Medellin, Colombia (3 months)
Cartegena, CO to N Chile (3 months)[/SIZE]
glasswave is offline
post #2 of 6 Old 05-24-2012, 04:17 PM
Toytech's Avatar
I have the answer for this one. With the gate down flat the bike will fit fine. HOWEVER, up to and including 2008 Tacomas have weak tailgate reinforcements built in. This does not indicate the thing is junk but under the narrow plane of the tire contact patch the gate could fold up into a V. This was mostly corrected by 2009. Is your Tacoma a Nuumi built or Mexico built unit? Us built the Vin starts with a 1.
I would recommend adding a sheet of 3/4 plywood in the bed and over the tailgate area. The bed has 2 sturdy tiedowns but you will need 2 more. The sliding holdowns on the rails are really not strong enough to carry the load of a 500lb bike.
Deflate the rear tires to lower the rear and use a sturdy ramp on the bed not the gate. When loaded re-inflate the tires. Now go home... or better yet just go get the bike and ride home. way more fun.
Toytech is offline
post #3 of 6 Old 05-24-2012, 05:38 PM
DGrav's Avatar
If it doesn't UHaul rents a motorcycle trailer for under $20 for 6 hours. I used one to pickup my 2012 650 Adv. one word of advice, recommended max speed is 55, at 53 it started swaying behind my F150 Raptor, I set the cruise at 51 and took the slow way home.
Musician, backpacker, Mt. Biker, learning how to be a motorcyclist.
DGrav is offline
post #4 of 6 Old 05-24-2012, 05:43 PM
Hauled mine 100 miles from the dealer to home about 6 weeks ago in a 2012 Tacoma extended cab. Bike fit fine with tailgate down--rear tire just barely on tailgate--actually on the gap if I remember correctly. Definitely use 4 straps--2 in front-2 in back--all pulling down and forward. Don't use the adjustable side hooks on the Tacoma-as stated previously they ain't up to the task. A piece of plywood on the tailgate might not hurt.
phoneman is offline
post #5 of 6 Old 05-24-2012, 05:51 PM
Why not have someone ride with you to pick it up, they drive the truck home, you ride the new bike
2012 DL650AL2
glass3222 is offline
post #6 of 6 Old 05-24-2012, 10:15 PM Thread Starter
glasswave's Avatar
Thanks for all the replies.
I will likely have to travel at least 500mi or more to get a new strom. I don't have a sig other or anyone else to talk into a massive 6 to 12 hr each way drive to accomplish the pick up of the bike. Furthermore, I do not want to spend my break in period going 80 on the interstate. (I'm down with the "ride it like you stole it" (well maybe a little less than that) break in method). At any rate, I want to avoid steady speeds.
My Tacoma is a 1999. It has 4 strong tie downs, one in each corner of the bed. I'll go tail gate down with plywood across the gap and 4 ropes.
Thanks again.
